Progress Pictures - 65 Coupe
  • Thread starter Thread starter truck90278
  • Start date Start date Nov 12, 2007
T
truck90278
382
Redondo Beach, CA
Nov 12, 2007
  • Nov 12, 2007
This is a followup on our 65 coupe project. You can see some pics of it after paint in our old thread:
http://forums.stangnet.com/showthread.php?t=701480
Engine is installed, should be able to start it up the 1st of December.
<img src="http://img254.imageshack.us/img254/1295/dsc02128qj0.jpg">
<img src="http://img254.imageshack.us/img254/9782/dsc02127ee0.jpg">
Shot of the hood and decklid.
<img src="http://img225.imageshack.us/img225/3748/dsc02129en1.jpg">
With the fiberglass decklid, we decided to use some gas struts instead of the torsion bars.
<img src="http://img225.imageshack.us/img225/7355/dsc02118sa3.jpg">
<img src="http://img103.imageshack.us/img103/3928/dsc02119rh9.jpg">
Heres a supplemental electrical panel we've made. Since we dont use the vent we cut it down and mounted a plate to it. Its only visible if you look under the dash. Includes a painless circuit, the remote actuator for keyless entry, the relays for the electric door locks, horn relay, and a circuit breaker.
<img src="http://img225.imageshack.us/img225/3584/dsc02121ez1.jpg">
<img src="http://img254.imageshack.us/img254/8866/dsc02122zs3.jpg">
BullittStangV8
1,104
NJ
Nov 12, 2007
  • Nov 12, 2007
wow very impressive. I love the color.
67FB
18
  • Nov 13, 2007
Diddo
geostang351
946
Danb., CT
Nov 13, 2007
  • Nov 13, 2007
EYE POPPING color! Nice
SoCalCruising
2,437
SoCal
Nov 13, 2007
  • Nov 13, 2007
I dig the gas strut for the trunk. Can you give details? Thanks.
valley82
204
San Diega, Ca.
Nov 13, 2007
  • Nov 13, 2007
VERY NICE!
G
Grabber70Mach
305
Indian Head, MD
Nov 13, 2007
  • Nov 13, 2007
Really nice looking, I like the color choice.
T
truck90278
382
Redondo Beach, CA
Nov 14, 2007
  • Nov 14, 2007
Glad too. We wanted to be able to add without welding or attaching anything to the fiberglass
For the bracket attaching the upper end to the spring:
We used a piece of 3/4" aluminum bar stock scrap we had laying around, cut it generally to shape and worked the final form with files and a small disc sander to get it to fit into the channel of the hinge, could probably use 1/2" minimum. With a snug fit, we drilled and tapped 1 hole thru the hinge into the aluminum block (5/16-18), It appears to work ok with only one screw as the block is curved and the sides are slightly beveled for a good fit into the hinge. On the side facing away from the hinge, we drilled and tapped two more holes which allowed for some minor adjustment, probably only needed one. These mnounting holes are tapped for a 8 MM course thread (the thread the ball studs come with).
Struts:
We used the "Strong Arm" brand of struts. If you go to their catalogue, they list several universal struts. We first started with 2 - 35 lb - 12 inch struts, these were not quite strong enough, so we used the 55 lb - 12 inch struts which did the job. If you wanted to move the lower mount more to the front of the car, you could go to a longer one, but you would have to experiment with the spring rate, the more the angle, the stiffer you would have to go. You would simply have to take a few measurements depending on where you want the lower mount. For our mounting position. the 12 inch, 55lb works nicely.
Lower Bracket:
Simply a scrap piece of 1/4" aluminum angle, without measureing, I believe it was 1 1/4" x 1 1/4",
Overall operation:
Works very smoothly with minimum effort. upon closing, the last few inches has no resistance due to the extremen small amount of travel of the strut. As the decklid is raised, the upper third of the travel, the deck lid tends to open itself. Remember this is a fiberglass deck lid which is a little lighter than steel. If we increased the spring rate, the opening would be stronger, also the angle of the strut affects the spring rate. Overall it was fairly easy and all accomlished with hand tools, It just took some time with the hand cutting
Hope this helps.
T
truck90278
382
Redondo Beach, CA
Nov 14, 2007
  • Nov 14, 2007
By the way, the color is Viper Blue Pearlescent, with Viper Silver Metalic
edgars23
80
Los Angeles Area
Nov 15, 2007
#10
  • Nov 15, 2007
  • #10
i need to go change my shorts. awesome paint job.
HistoricMustang
2,359
Confederate States of America
Nov 15, 2007
#11
  • Nov 15, 2007
  • #11
Very nice!
HistoricMustang
www.historicmustang.com
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Nov 15, 2007
#12
  • Nov 15, 2007
  • #12
Whoa! Awesome
CraigMBA
783
Orange, CA
Nov 15, 2007
#13
  • Nov 15, 2007
  • #13
Nice hinges.
reenmachine
20+ Year Stangneter
Jun 27, 2004
1,258
Montrose, CA
Nov 19, 2007
#14
  • Nov 19, 2007
  • #14
Awesome looking! Kudos to the paint & body guy.
MedievaL
Warrior, Alabama, USA
Nov 21, 2007
#15
  • Nov 21, 2007
  • #15
very nice!
J
jamison42166
112
#16
  • Nov 21, 2007
  • #16
I love blue !!!!! awesome~!!!!
My 65 coupe pics!!
  • AdamInChains
  • May 5, 2006
2K
Classic Mustang Specific Tech May 7, 2006
AdamInChains
