Projector Headlight Lightbulbs?
  • Thread starter Thread starter El Horsepower
  • Start date Start date Feb 22, 2008
E
El Horsepower
15
  • Feb 22, 2008
I picked a set of these up for $50 off of my local craigslist brand new. I know, I know everyone here says they are crap but for the price I wanted to give it a try. Anyways, there are two main lightsources on the front as you can see.
The bulb that came in slot 2 is marked "9006". However, the lightbulb that I pulled out of my stock headlights is marked "9007" Which is brighter? Should I put my old one into slot 2? Also, which is the main headlight, 1 or 2? When I turn on my lights, will they both come on? Which one serves as the high beam? Thank you for the help in advance!
D
Dark_Pony94
36
  • Feb 22, 2008
I believe that the 9006 and 9007 at two completely different bulbs. Its not which is brighter. From what I remember they have different connectors on them to fit the harness. I would imagine that the 2 would be your highs, and 1 is your lows
Bosko5.0
1,067
longwood, FL
Feb 23, 2008
  • Feb 23, 2008
wouldn't 1 be for both high/low and 2 for just low. Did they come with instructions?
What size bulb came out of 1 ???
E
El Horsepower
15
  • Feb 23, 2008
No instructions at all. 1 has a H3 and 2 has a 9005. Im pretty sure 1 is the high beam now.
D
DarkStallion095
93
Rancho Santa Margarita, CA
Feb 23, 2008
  • Feb 23, 2008
bulbs
I think the numbers on the bulbs are just for fitment. They are not used to describe brightness unless it is a Kelvin rating (K). But no the numbers you are mentioning are just for the connector/harness they will work with. The main light is your projector (1) and when you turn on your brights, projector turns off, and number 2 turns on. Number 2 is your brights and whether or no you wire in halo's or LED's is up to you. Pretty easy to install. I've done it a few times. The barch is the wiring of the halo's and or LED's to parking lights.
95strokerPSU
986
Sacramento from Philly
Feb 23, 2008
  • Feb 23, 2008
From what I remember the H3 should be your low beam bulb. If I was you, I'd get the brightest bulb possible, something like the sylvania silverstars. Those projectors kill the light output and makes almost dangerous to drive on unlight roads with regular bulbs. Good luck with them.
Blackened302
1,439
South TX
Feb 23, 2008
  • Feb 23, 2008
they should have come w/ a wiring harness - one end goes into the new bulbs (9006 for lows and 9005 for highs) and the other end plugs into your stock 9007 connection.
1987Rock
114
  • Feb 23, 2008
I've got these same lights right now and they SUCK!!!!!
Bulb one is the low/main and 2 is the high beam.
The main reason they suck so bad is that you can't adjust them properly. They have 3 mounting tabs, but the bottom one next to the fender is not adjustable, so they end up pointing down too far.
Not only that, but when you adjust the drivers side to point away from oncoming traffic like it should, it pulls the corner light out from the fender and it looks like *****!
As far as the bulbs, the 9006 is in mine. Definitely gonna get some silvanias soon or something. They make HID kits for them now that I'm gonna look into b/c I love the look of these.
E
El Horsepower
15
  • Feb 24, 2008
Are the wire harnesses necessary if I get bulbs that match the stock wattage?
C
Colinhamid
#10
  • Feb 24, 2008
  • #10
Headlight
I tried similar set projector head lights and was very disappointed expecting to see bit further than 50 ft ahead. No instructions with the install they look nice but offer no improvement over stock. Any recommendations? Anyone happy with their new head lights or are those Sylvania lamps worth the money and as good as they will get?
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
K
2003 Mustang GT Convertible Headlight H/L Issue
  • krysber
  • Mar 20, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 21, 2025
85GTStangGuy
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
