  • SN95 4.6L Mustang Tech
Prove your Mustang knowledge
  • Thread starter Thread starter poolee
  • Start date Start date Mar 1, 2004
1 of 2 Next Last
poolee
97
melbourne, fl
Mar 1, 2004
  • Mar 1, 2004
All right, situation is...
Key in the ignition, car is in park, turn the key to "on", all the idiot lights are normal, the fuel pump primes, radio turns on. Turn the key to "start", and all you hear is the faint click of the solenoid. No spinning starter, no roaring exhaust, just crickets out by the road. In the distance, a baby cries because she can't see your beautiful car rolling down the street destroying all ricers and Z28s in its path.
This problem just started up last Thursday at work. About 3 hours after I got to work, I went out to go to the gym, the starter didn't spin, so I tried again and it fired right up. On Saturday afternoon, it did it again, so I checked all my high current fuses and then the anti-theft fuse. After about 15 minutes of looking around for problems, it mysteriously starts. Then it ran fine for the rest of the day. I probably started it 3 or 4 more times that day. It sat in the drive on Sunday. Then, this morning I went out to go to work and it didn't start, so I looked around for a couple of minutes and then drove the Firebird. The battery is only a year old and the alternator is 5 months.
Anyone got a similar horror story, or a really big bat?
"Fix Or Repair Daily" is turning out to be a reality.
THANKS FOR PLAYING!
M
millatime
370
Palm Harbor, FL
Mar 1, 2004
  • Mar 1, 2004
could be that your starter is going...or could be a problem I had on my old car. If you don't have the terminals screwed tightly enough on the battery it will sometimes not start. you might want to check these two things out.
J
jmichalicek
274
Richmond, Va
Mar 1, 2004
  • Mar 1, 2004
Mine did this a few weeks ago. Started up fine in the morning, I went to leave work and nothing. Tried a few more times and it works. Same thing next day... cranks right up in the morning, nothing at work. Has worekd fine since then. No ideas wtf the deal is.
Bone Racing
1,075
Long Island, NY
Mar 1, 2004
  • Mar 1, 2004
the starters have a round spinning wheel on em with ridges kinda like a stars POINTS....it moves when u try to start the car....
u prolly started the car and it stopped prinning BETWEEN the POINTS
thats why u see people HITTING the starter sometimes...to move it to where the METAL ignition fork touches the points
9
99SCGT
KANSAS
Mar 1, 2004
  • Mar 1, 2004
CHECK THE BATTERY CONNECTIONS FIRST. THEN CHECK FOR CORROSION UP INTO THE BATTERY CABLES THEMSELVES BY CUTTING BACK THE INSULATION A LITTLE. AFTER THAT CHECK CONNECTION AT THE STARTER. IF OK THEN CHECK THE SYSTEM FOR HIGH RESISTANCE BOTH NEG SIDE AND POS SIDE. IF THIS IS OVER YOUR HEAD TAKE IT TO A SHOP. WITH THE SYMPTOMS YOU DESCRIBE YOU HAVE A LOW BATT OR HIGH RESISTANCE IN THE SYSTEM SOMEWHERE.
NiteRydaGT
295
Long Island, NY
Mar 1, 2004
  • Mar 1, 2004
Sounds similar to what happened to me when my TPS(Throttle Positioning Sensor) went out. Car started fine one minute, nothing the next. Give that a shot.
'96&'01Stang
798
Georgia
Mar 1, 2004
  • Mar 1, 2004
It is probably either the battery or the battery cables like 99scgt said
R
Roger_4.6_96
1,209
Reno,NV
Mar 1, 2004
  • Mar 1, 2004
i had a similiar problem and thought it was the starter. turned out to be my alarm
Dan_Soprano
7,410
54
129
Jacksonville, FL
Mar 1, 2004
  • Mar 1, 2004
Nicely said. Also, if your starter got really wet recently then there could be corrosion on the brushes inside the starter.
StangJonGT
1,329
Seattle
Mar 1, 2004
#10
  • Mar 1, 2004
  • #10
99 times out of a 100 this is a connection issue. Check all of your connections, battery first, and see what you find. A simple cleaning with an anti-corrosion fluid and wire brush will probably make it run like new.
Jon
poolee
97
melbourne, fl
Mar 1, 2004
#11
  • Mar 1, 2004
  • #11
This intrigues me...the car had been idling quite high occasionally after starting, cold and warm. Most of the time it idled normal, sometimes it would get up to about 1800 for a few seconds. This just started about a month ago. I was attributing this to a dirty IAC or old vacuum lines.
Was the TPS the only thing keeping the car from starting?
You know how when you try to start the car and you're either still in gear or the clutch isn't pushed in all the way? Everything is normal but it won't turn over. That's how this feels.
I checked the battery side for corrosion, but I can't get under the car to check the starter, so I'll hit the rack later this week (if I can get there).
Thanks for all the inputs. I'll keep this updated. No one likes to search the forums and look up unresolved problems.
J
JB9789
12
#12
  • Mar 1, 2004
  • #12
I have seen a leaking injector causing this problem but it ended up bad.
hydrolock!!!
do you smell a fuel smell?
asthmaticZeater
1,341
Jeffersonville, IN
Mar 1, 2004
#13
  • Mar 1, 2004
  • #13
Jon
now, i know there are 40 some people throwing out suggestions here trying to prove their mustang knowledge. but im with this guy. ive had this same thing with mine. id go to start it and itd just click, so id try it again a few times, clicking each. and randomly, itd start. go to start it next time, bang. 45 minutes later, clicking.
check your connections. my battery connections were good so i took the ones off the starter and cleaned them. havent had the problem since.
C
cltgt
931
Geneva, Fl.
Mar 1, 2004
#14
  • Mar 1, 2004
  • #14
my car did that for a while. Went away after i had to replace the starter...
'96&'01Stang
798
Georgia
Mar 2, 2004
#15
  • Mar 2, 2004
  • #15
N
n0v8or
604
Rhode Island
Mar 2, 2004
#16
  • Mar 2, 2004
  • #16
Mounted on top of the starter, but usually considered integral to it, is a combination actuator/contactor (fancy name for a big fat relay). When you turn the key to "start", the actuator pushes the drive gear into mesh with the flywheel. Near the end of the stroke, contacts complete the circuit between battery and motor.
While I agree that poor battery connections and a high resistance cell are more common causes, I have had the actuator assembly become "gummed up", and intermittent. Four out of five times the actuator will not advance far enough to close the contacts. This actuator can be replaced separately, but most just buy a complete new starter, since you have to remove the starter anyway to clean and/or replace the actuator. This problem is not unique to Fords.
D
Daves4.6GT
163
#17
  • Mar 2, 2004
  • #17
This Isn't Mustang Knowledge.......anyone with a battery could tell you its a bad Connection...... wiggle the battery connection.....it should be fine.
Dave
merc123
420
North GA
Mar 2, 2004
#18
  • Mar 2, 2004
  • #18
My Cougar had a problem like this. Turned out to be the starter and flexplate in the transmission (AOD).
NasaGT
1,993
Virginia
Mar 2, 2004
#19
  • Mar 2, 2004
  • #19
This is exactly what my car did - Ford replaced the starter.
'96&'01Stang
798
Georgia
Mar 2, 2004
#20
  • Mar 2, 2004
  • #20
yea like Ford service centers are the best
1 of 2 Next Last
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
C
No Crank--have power(accessories)
  • chazmanaz
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 17, 2025
chazmanaz
C
  • brandyn200
  • Jun 20, 2026
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
