Pull A Thon
  • Thread starter Thread starter Lovejoy
  • Start date Start date Jul 9, 2016
1 of 2 Next Last
Lovejoy
Jerking And Popping
Jan 3, 2016
94
Illinois
Jul 9, 2016
  • Jul 9, 2016
going to a pull a thon tomorrow all you can carry for $50.00 wondering if it's only 96-97 explorers that the heads would work or any 5.0 they made. And what years was that an option for explorers
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 9, 2016
  • Jul 9, 2016
The V8 Explorer 95-99 heads will all work; some may require different headers and spark plug wire to work properly.
The heads with the 3 bars cast into the end of the head are the 95-97 GT40 heads. These are the only heads that will work with the stock 5.0 Mustang EGR. If you have smog inspections in your area, this is a consideration. They also work with both stock and aftermarket headers.
The heads with 4 bars cast into the end of the heads are GT40P. They have a different angle on the spark plugs and may require special spark plug wires or/and or shorter spark plugs. Some aftermarket heaters don't fit GT40P heads. They also do not have EGR passages cast into the heads, so thy won't pass smog inspection in areas that do smog tests.
Reactions: 7991LXnSHO
Lovejoy
Jerking And Popping
Jan 3, 2016
94
Illinois
Jul 9, 2016
  • Jul 9, 2016
so the gt-40P's you have to delete the egr I was told just have to upgrade springs. which should be done either way. sounds like p's are a waste of energy
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 9, 2016
  • Jul 9, 2016
The GT40P flow better as cast and have a potential to make more power, but have the problems I listed above. You need to upgrade the valve springs on both GT40 & GT40 P heads. If you do not live in an area where there are emissions inspections, then you can user either set of heads.
Hopefully, someone who is actually running GT40P heads will chime in and tell us more about the header and spark plug wire issue.
Lovejoy
Jerking And Popping
Jan 3, 2016
94
Illinois
Jul 9, 2016
  • Jul 9, 2016
That's really what I'm worried about. Gonna update anyway but if I can't run Mac headers with em then I'm screwed. Emissions is no problem around here running dumps with no cats and smog delete. Yard has about 10 cars from 96-98 so hoping to find a couple sets
stykthyn
5,232
2,652
223
gainesville
Jul 10, 2016
  • Jul 10, 2016
Good times. I pulled a 96 explorer 5.0 at one of those. Factor in clean up and machine time I had a gt40 engine for under 300 bucks.
Lovejoy
Jerking And Popping
Jan 3, 2016
94
Illinois
Jul 10, 2016
  • Jul 10, 2016
Wanting gt40 not gt40p's. Found 2000 mountainer first then a 96 awd explorer. Me vs the Explorer the Explorer won. And we're gt40p's. Idk if that's all awd's or what. All in all waste of my time. Just made it easier for the next person
stykthyn
5,232
2,652
223
gainesville
Jul 10, 2016
  • Jul 10, 2016
Not sure what you are telling us
Lovejoy
Jerking And Popping
Jan 3, 2016
94
Illinois
Jul 10, 2016
  • Jul 10, 2016
That I tore into it for a couple hours and came out with nothing.
stykthyn
5,232
2,652
223
gainesville
Jul 10, 2016
#10
  • Jul 10, 2016
  • #10
Why not? Heads are easy.
Lovejoy
Jerking And Popping
Jan 3, 2016
94
Illinois
Jul 10, 2016
#11
  • Jul 10, 2016
  • #11
No breaker bar and truck was 3 ft off the ground. And had time limit. Been sitting for who knows how long. Odds weren't with me. Never have done it anyway.
stykthyn
5,232
2,652
223
gainesville
Jul 10, 2016
#12
  • Jul 10, 2016
  • #12
Bummer. Yeah, when removing big pieces a breaker bar and mallet are mandatory. Honestly if they provided a hoist just taking the whole engine may have been the better option. Everything on that block has resale. Early bronco and f100 guys want the serpentine set up. Intake sells right away, alternator is a 3g upgrade. that whole engine is money and they aren't as common as they used to be. Cash for clunkers killed them.
Lovejoy
Jerking And Popping
Jan 3, 2016
94
Illinois
Jul 10, 2016
#13
  • Jul 10, 2016
  • #13
Not a seasoned vet here
stykthyn
5,232
2,652
223
gainesville
Jul 10, 2016
#14
  • Jul 10, 2016
  • #14
No worries. We all start at the bottom.
Lovejoy
Jerking And Popping
Jan 3, 2016
94
Illinois
Jul 10, 2016
#15
  • Jul 10, 2016
  • #15
Should have pulled motor like you said tho. Wasn't prepared for the battle. Broke a lower intake bolt anyway. And the rear one wouldn't come out for anything so that one would have broke as well. They have plenty more so going again soon
9
92NOTCH01
Well-Known Member
May 14, 2016
188
96
63
Jul 10, 2016
#16
  • Jul 10, 2016
  • #16
Did you try looking on eBay?
Sent from my iPhone using Tapatalk
Lovejoy
Jerking And Popping
Jan 3, 2016
94
Illinois
Jul 10, 2016
#17
  • Jul 10, 2016
  • #17
On tight budget. Plus like to say I did the work
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Jul 10, 2016
#18
  • Jul 10, 2016
  • #18
should hav cut all the hoses, wires, unbolted the motor and trans, cut the exhaust and yanked it all out in one piece, then dissamble off the car
Reactions: stykthyn
Lovejoy
Jerking And Popping
Jan 3, 2016
94
Illinois
Jul 10, 2016
#19
  • Jul 10, 2016
  • #19
Shoulda coulda woulda lol. I know now easier ways to go about it. Truck had a lot of miles anyway should have looked around a little longer for better candidate
Mustang5L5
Mod Dude
Feb 18, 2001
43,353
18,092
224
Massachusetts
Jul 10, 2016
#20
  • Jul 10, 2016
  • #20
eBay prices have been going up. Seeing exploder intakes creeping up to almost $200 plus shipping these days.
I'd attribute that to the discontinuation of the 1993 cobra Chinese intake
How many fox mustangs out there still have a stock HO intake on them?
Sent from my big ass iPhone 6 using Tapatalk
1 of 2 Next Last
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
  • Mindseye007
  • Aug 16, 2026
Mindseye007
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
