Pulled Code 31, how do I fix it?
  • Thread starter Thread starter 22Stang
  • Start date Start date Jul 27, 2004
22Stang
26
Bay Area, CA
Jul 27, 2004
  • Jul 27, 2004
Pulled Code 31 on my '92 5.0. How do I fix this problem, I already changed the EGR and Sensor. Please Help
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Jul 27, 2004
  • Jul 27, 2004
did you reset the eec to clear the memory code after you fixed the egr stuff?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 27, 2004
  • Jul 27, 2004
CODE: 31 (KOEO) - EVP circuit below minimum voltage. Vref missing or broken wire or bad contact in circuit. Check for 5 volts on the orange/white wire. With the sensor removed from the EGR and still connected, press the plunger and watch the voltage change on the brown/lt green wire. Use the black/white wire for the voltmeter ground. Check for the same results on pin 27 on the computer. Check for continuity between the wiring at the sensor and the computer. The brown/lt green wire on the sensor & pin 27 should be less than 1 ohm. The black/white wire on the sensor & pin 46 should be less than 1 ohm. The orange/white wire on the sensor & pin 26 should be less than 1 ohm.
22Stang
26
Bay Area, CA
Jul 27, 2004
  • Jul 27, 2004
yeah, I Cleared the codes using the scanner and I disconnected the Battery for 30 mins to try and get the hard codes cleared and I still get 31. Any ideas, the check engine light has been coming on alot, mostly when getting off the Freeway.
mustangsquared
828
new bern nc
Jul 28, 2004
  • Jul 28, 2004
22Stang...
Same problem...I replace all the EGR crap and I am still getting code 31...and the check engine light. Are you running a little hot? EGR stuck in the closed position should result in hotter engine temps (also a problem I have). I am going to clean it again.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jul 28, 2004
  • Jul 28, 2004
Read jrichker's post above guys - it gives you a step by step on what to do to determine where the problem is. The bits you've replaced aren't the problem - "Vref missing or broken wire or bad contact in circuit." That's the problem. The diagnostic above is straight from an authorized ecu trouble shooting guide. He knows his stuff - check out the rest of the circuit/wiring/connections.
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
