Pulled KOER code 91 ...
  • Thread starter Thread starter dubbsix
  • Start date Start date Dec 23, 2006
1 of 2 Next Last
dubbsix
347
Katy,TX
Dec 23, 2006
  • Dec 23, 2006
It says bank 2 is running lean. Which side is bank 2?!
Reactions: MikeH686
Bigstang1
415
Massachusettes
Dec 23, 2006
  • Dec 23, 2006
Drivers side
dubbsix
347
Katy,TX
Dec 23, 2006
  • Dec 23, 2006
Related question
is the 91 error definitely a failing o2 sensor? I also have some fuel pressure issues as my pump is making a very pronounced "humming" sound when the car is running.
68torinogt
Hey guys, guess what--I have a bi-pass!!!
Mar 21, 2006
Welcome my son, welcome to the machine
Dec 23, 2006
  • Dec 23, 2006
fuel pumps hum loud and the o2 should fix the problem.
but if you really have a fuel problem fix it first,
dubbsix
347
Katy,TX
Dec 23, 2006
  • Dec 23, 2006
Well me having a fuel issue is only because the pump is just plain loud when the car is running. I had a similar problem with another car and when i changed the fuel pump it quieted down again. Someone told me the pumps start to hum loud when they are bout to die... is that true?
68torinogt
Mar 21, 2006
Dec 23, 2006
  • Dec 23, 2006
not necessaraly, mine hums and has always. and camaro's hum too
dubbsix
347
Katy,TX
Dec 23, 2006
  • Dec 23, 2006
Cool i gotcha man. Thanks. When i score myself a o2 socket i'll get to work on removing the driver side.... Is it one of those things were i should change the passenger side while im under there?
68torinogt
Mar 21, 2006
Dec 23, 2006
  • Dec 23, 2006
i would see how much they are first. if it is like $10 bucks then i would but if it is like 50 then hell no
68torinogt
Mar 21, 2006
Dec 23, 2006
  • Dec 23, 2006
be sure to use the anti seize on the o2 sensor.
HISSIN50
34
129
Dec 23, 2006
#10
  • Dec 23, 2006
  • #10
I'd check the signal on the code-throwing O2. Look for proper frequency and amplitude of switching.
If the FP was the issue, chances are you'd see both banks spit an O2 code or none spit the code. Additionally, it would likely ping or drop pressure (as a result of lackluster volume) at WOT.
Good luck.
68torinogt
Mar 21, 2006
Dec 23, 2006
#11
  • Dec 23, 2006
  • #11
it would possibly be hard to start as well if it were a fp
dubbsix
347
Katy,TX
Dec 23, 2006
#12
  • Dec 23, 2006
  • #12
I am new to stangs so im learning along the way. It does have an weird idle stumble.. i cant figure out what it is.. but that doesnt mean its fuel either. Did i mention the car has 200K+ on the stock pump?!
68torinogt
Mar 21, 2006
Dec 23, 2006
#13
  • Dec 23, 2006
  • #13
generally when a pump is bad you will not be able to even start the car. it shouldnt be the pump at all.
some minor thinks i would start off with is
clean the mass air sensor
change the o2
if problems persist with the stumble then pm me and i will work you thru some more items to check.
does it do anything else?
what year is it?
was it taken care of?
do you have pics?
89streetbeast
365
horton,ks
Dec 23, 2006
#14
  • Dec 23, 2006
  • #14
i'd check your fpr, might be bad also.
dubbsix
347
Katy,TX
Dec 23, 2006
#15
  • Dec 23, 2006
  • #15
68torinogt,
Thanks for the invitation. I will change those things and report back.
Where the heck is the regulator located on the stang?
its an 89LX
68torinogt
Mar 21, 2006
Dec 23, 2006
#16
  • Dec 23, 2006
  • #16
dubbsix said:
68torinogt,
its an 89LX
mass air or air density?
it makes alot of diff.
i think it is on the fuel rail
dubbsix
347
Katy,TX
Dec 23, 2006
#17
  • Dec 23, 2006
  • #17
Its a Mass Air and i did recently clean the MAF and it seemed to smooth out a bit but every now and then i'll get a stumple like the car wants to die. It even serged a bit today after some 'spirited' driving.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 24, 2006
#18
  • Dec 24, 2006
  • #18
Per HISSIN50's recommendation, check the voltage output of the O2 sensor first. At $40 a piece, they are not cheap. It is best to replace them in pairs, because if one is bad, the other is not far from failing.
Code 41 or 91 - O2 indicates system lean. Look for a vacuum leak or failing O2 sensor.
The computer sees a lean mixture signal coming from the O2 sensors and tries to compensate by adding more fuel. Many times the end result is an engine that runs pig rich and stinks of unburned fuel.
The following is a Quote from Charles O. Probst, Ford fuel Injection & Electronic Engine control:
"When the mixture is lean, the exhaust gas has oxygen, about the same amount as the ambient air. So the sensor will generate less than 400 Millivolts. Remember lean = less voltage.
When the mixture is rich, there's less oxygen in the exhaust than in the ambient air , so voltage is generated between the two sides of the tip. The voltage is greater than 600 millivolts. Remember rich = more voltage.
Here's a tip: the newer the sensor, the more the voltage changes, swinging from as low as 0.1 volt to as much as 0.9 volt. As an oxygen sensor ages, the voltage changes get smaller and slower - the voltage change lags behind the change in exhaust gas oxygen.
Because the oxygen sensor generates its own voltage, never apply voltage and never measure resistance of the sensor circuit. To measure voltage signals, use an analog voltmeter with a high input impedance, at least 10 megohms. Remember, a digital voltmeter will average a changing voltage." End Quote
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear. The computer pins are 29 (LH O2 with a dark green/pink wire) and 43 (RH O2 with a dark blue/pink wire). Use the ground next to the computer to ground the voltmeter.
Most of the common multimeters have a resistance scale. Be sure the O2 sensors are disconnected and measure the resistance from the O2 sensor body harness to the pins on the computer.
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter. Do not attempt to measure the resistance of the O2 sensors, it may damage them.
The O2 sensor ground (orange wire with a ring terminal on it) is in the wiring harness for the fuel injection wiring. I grounded mine to one of the intake manifold bolts
68torinogt
Mar 21, 2006
Dec 24, 2006
#19
  • Dec 24, 2006
  • #19
what manual is this from?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 24, 2006
#20
  • Dec 24, 2006
  • #20
After 6 years and 10,600+ posts, I have written one in pieces and parts responding to Stangnet posts.
The Probst book I metioned is an important part of a Mustang library. Here's a book that will get you started with how the Ford electronic engine control or "computer" works.
Ford Fuel Injection & Electronic Engine Control 1988-1993 by Charles Probst :ISBN 0-8376-0301-3.
It's about $20 from Borders.com see http://www.amazon.com/ . Select boo...very good, and I found it to be very helpful.
1 of 2 Next Last
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
G
Help! 93 Mustang 2.3L A4LD dies at idle
  • goofyfoot53
  • Nov 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
goofyfoot53
G
