pulledcodes...need help
  • Thread starter Thread starter wshI_hd_1
  • Start date Start date Dec 2, 2004
W
wshI_hd_1
94
paulding, ga.
Dec 2, 2004
  • Dec 2, 2004
my car been intermittently running like crap lately so i pulled some codes, and all i got was o2 sencor and AIR. My first question is, what side is the terminal one o2 on, passenger or driver side and my second question is, wha the heck is AIR>? Is it my mass air sensor?
thanx
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Dec 2, 2004
  • Dec 2, 2004
what were the code numbers?
bryanrevans
296
Chicopee,Mass
Dec 2, 2004
  • Dec 2, 2004
AIR is a couple of codes isnt it??
W
wshI_hd_1
94
paulding, ga.
Dec 2, 2004
  • Dec 2, 2004
codes are 82)air bypass secondary air injection...42) Heated O2 bank 1 / mixture rich/ not switching
The Shape
2,224
East ARKANSAS Delta
Dec 2, 2004
  • Dec 2, 2004
82 has to do with your smog pump system, is yours deleted? If so just ignore it. As far as the o2 sensors go if yours are still original it would probably be best to just replace both.
bryanrevans
296
Chicopee,Mass
Dec 2, 2004
  • Dec 2, 2004
Whats it doing?At what rpm range,Idle,Drivin??
W
wshI_hd_1
94
paulding, ga.
Dec 2, 2004
  • Dec 2, 2004
its bucking really bad, sputtering, and wont go anywhere, and its intermittent
bryanrevans
296
Chicopee,Mass
Dec 2, 2004
  • Dec 2, 2004
trace back to something youve done recently,I mean like something as minor as timeing ajustment(spout connector left out map unplugged,ect.It seems like with all the mods you have, you know your car best.
bryanrevans
296
Chicopee,Mass
Dec 2, 2004
  • Dec 2, 2004
Dump codes and drive in all ranges and cinditions to try to pop another code or if same ones pop again you can focus there??
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 3, 2004
#10
  • Dec 3, 2004
  • #10
Are you sure you got a 42? Most of the problems come with a code 41 (bad O2 sensor). Here's the info for code 42...
Code 42 (running) System rich - Fuel control or (memory) System was rich for 15 seconds or more (no HO2S switching) - Fuel control. Look for leaking injectors, fuel pressure too high, cylinder(s) not firing due to bad ignition.
Code 82 – Secondary Air Injection Diverter Solenoid failure AM1. The dump valve air diverter valve (front vacuum operated valve) isn’t working on the Thermactor Air System (smog pump). Look for broken or missing vacuum lines on the solenoid valve to the diverter valve Check the solenoid valve for +12 volts at the Red wire and look for the Red/White wire to switch from +12 volts to 1 volt or less. The computer controls the valve by providing a ground path on the Red/White wire for the solenoid valve
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
M
05 Mustang GT With Annoying P0463 Issue
  • Machbud
  • Oct 17, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 24, 2026
manicmechanic007
