Pulleys + Power Steering ???????
  • Thread starter Thread starter SHIFTY101EASY
  • Start date Start date May 3, 2006
SHIFTY101EASY
129
  • May 3, 2006
ok my car came with power steering on the 289, i have a newish 302 in there now with the power steering all hooked up on it and everything but the guy took off the dual groove stock pulleys to put on single groove underdrive pulleys....
i want to hook up the power steering again but am wondering if i need to get a dual groove water pump pulley or crankshaft pulley or does it not matter....thanks!
My car is 1968 coupe with 302 by the way....no A/C just P/S.
Is it possible to get a serpintine setup to work with the power steering pump....??? its got a V belt on it and ive never see a replacement pulley for power steering pumps.....??
67topless
203
Raleigh, NC
May 3, 2006
  • May 3, 2006
I have a dual groove pulley on my crank... the outer-most groove runs the power steering and the inner runs the water pump and alternator.
Scott
SHIFTY101EASY
129
  • May 3, 2006
so im assuming even though the pulley says its for a boss 302, it will work on my regular 302 since the only difference between those engines is the heads?
D
D.Hearne
11,730
south louisiana
May 3, 2006
  • May 3, 2006
The Bosses also had a thicker balancer, you might get into pulley alignment issues with a Boss pulley. Only way to know is try it, or find someone that has one and compare the diameter and offset specs.
SHIFTY101EASY
129
  • May 3, 2006
i wish there was a crank pulley for just a regular for small block somewhere that wasnt in like a pulley kit for like 170 bucks!
it would bother me to buy a whole new set up of pulleys when the previous owner JUST put these new under drive pulleys on......
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
D
Power steering pump bracket with A/C
  • Dczookster
  • Apr 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 2, 2025
rednotch
Question about power steering.
  • 2003 mustang gt modded
  • Oct 23, 2024
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 15, 2024
manicmechanic007
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
P
Suspension 88 GT- trying to diagnose power steering issue
  • pindude80
  • May 26, 2024
Fox 5.0 Mustang Tech May 27, 2024
AeroCoupe
