Pulling Codes
  • Thread starter Thread starter dcurtis
  • Start date Start date Jul 2, 2007
dcurtis
688
Jul 2, 2007
  • Jul 2, 2007
Exactly how do I pull codes? I have a 91 GT, I am wanting to do the test light way of pulling codes.
LaserSVT
3,543
233
Jul 2, 2007
  • Jul 2, 2007
Check out the useful technical thread sticky. Real easy.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 2, 2007
  • Jul 2, 2007
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
LaserSVT
3,543
233
Jul 2, 2007
  • Jul 2, 2007
Check out the useful technical thread sticky. Real easy. It will give you the codes for on and running. Saved me alot of headache
dcurtis
688
Jul 2, 2007
  • Jul 2, 2007
So I connect the self test input to the number 2 spot (computer test ground) and use the test light on the number 4 spot (lead to check engine light), sorry I guess I am just making this harder than it really is because I don't understand it.
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Jul 3, 2007
  • Jul 3, 2007
Re-read it a couple times it will make sense, its an easy process.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 3, 2007
  • Jul 3, 2007
If your check engine light comes on when you first turn the ignition switch to Run, all you need is a paper clip.
Jumper the self test input dangling wire beside the test connector and the test connector ground. Get in the car and turn the ignition switch to Run and watch the flashes.
dcurtis
688
Jul 3, 2007
  • Jul 3, 2007
OK, finally figured it out, I thought I had to use a test light, all I did was stick a paper clip in the two wires above and got in the car, it flashed twice long pause flashed twice, then flashed 9 fast then 5 fast, but the 95 is fuel puimp power isnt it, my fuel pump works perfectly. What were the other two slow and two slow flashes?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 3, 2007
  • Jul 3, 2007
The 95 code is because at one time or another, the fuel pump relay hiccupped and didn't provide power the pump when the computer told it to run. Sometimes this is a one time thing, other times it is a no run or runs poorly condition.
KENS89LX
302
Cross lanes Wv
Jul 4, 2007
#10
  • Jul 4, 2007
  • #10
The easiest way I found is go to Autozone, they do it for free..
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
F
Help with air bag code 2293
  • Felwinters
  • Apr 23, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Apr 23, 2026
Felwinters
F
Electrical Dash wiring
  • RileyDymond
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 19, 2026
RileyDymond
