Pulling Codes?
  • Thread starter Thread starter TrickFlowd
  • Start date Start date Oct 12, 2007
TrickFlowd
240
Sayre, PA
Oct 12, 2007
  • Oct 12, 2007
I need to check my car to see if it is throwing any codes. I'm almost positive that the retards at autozone where I live won't be able to figure it out. So just incase, if I go there and this is true...does anyone have any info on how to do it myself with their equipment? 87-93 fox's are OBD1 right?
ninety15.0
1,336
  • Oct 12, 2007
Yes they are OBD-I. You can pull codes yourself with a paperclip if you want. Its very simple. Do a search for jrichker's surging idle checklist. There should be information in there about which pins to connect the paperclip to. good luck
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 12, 2007
  • Oct 12, 2007
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
F
Help with air bag code 2293
  • Felwinters
  • Apr 23, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Apr 23, 2026
Felwinters
F
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
P
CEL light on and Can't pull KOER codes.
  • psfoxstang
  • May 7, 2024
Fox 5.0 Mustang Tech Jun 20, 2024
psfoxstang
P
J
Thanks for the information on codes 31,34,44 and 94!
  • JK86LX50
  • Mar 5, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 5, 2025
gkomo
