  • 1994 - 1995 Specific Tech
Pulling Motor
  • Thread starter Thread starter 89llx
  • Start date Start date Sep 8, 2017
89llx
5 Year Member
Aug 31, 2009
302
Sep 8, 2017
  • Sep 8, 2017
can i pull th 5.0 motor on my 95 gt and NOT lose my airconditioners freon or will i have to take the lines apart
thanks
jozsefsz
1,243
332
124
Cleveland OH Area
Sep 9, 2017
  • Sep 9, 2017
You can pull it with the lines connected, removing the PS pump will let the lines clear, and removing the battery gives you some more working room. Personally I like to get the compressor and lines out of the way (they always get in my way) - the '95 is R134a so replacing isn't very expensive (you can have the refrigerant recovered at a shop if you're legally and environmentally conscious). I also like to pull everything down to the short-block before I put the chains on the engine but that's just me.
Reactions: ursixx and imp
89llx
5 Year Member
Aug 31, 2009
302
Sep 10, 2017
  • Sep 10, 2017
thanks
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Sep 13, 2017
  • Sep 13, 2017
It will all rotate out of the way. The quick disconnect fitting rotate freely. Rotate it over to the right side of the car carefully. Put a thick towel over the passenger side fender, and use a bungie chord around the wheel to hold the compressor out of the engine compartment.
Kurt
L
Door pull panels, convertible versus coupe
  • lenzgt
  • Jun 25, 2026
1994 - 1995 Specific Tech Jun 25, 2026
lenzgt
L
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
2010 GT AC issue
  • 2010torchredgt
  • Jun 28, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jun 29, 2026
2010torchredgt
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
Electrical No dash lights
  • slojoexxx
  • Dec 11, 2025
1994 - 1995 Specific Tech Dec 11, 2025
slojoexxx
