****Pulling out gauge cluster, please help ASAP****
  • Thread starter Thread starter BlownStangGT
  • Start date Start date Feb 26, 2004
BlownStangGT
REPEAT
3,860
Lancaster, PA
Feb 26, 2004
  • Feb 26, 2004
I am trying to pull my guage cluster and I got the coinnect on the drivers side, but towards the passanger side of the car there is a silver tube and a white thing, i can not get it off, how do I ge4t this off. I am tyring ot pull my dash out in the next 5 min or so, so if you know please reply ASAP
87gtconv
ragtopman
2,595
Southern Calif
Feb 26, 2004
  • Feb 26, 2004
R U talking about the speedo cable??
SLiM JiM 156
1,024
Rohnert Park, CA
Feb 26, 2004
  • Feb 26, 2004
i remember doing this in my old car, is it the one that the cable goes into?
BlownStangGT
REPEAT
3,860
Lancaster, PA
Feb 26, 2004
  • Feb 26, 2004
yeah I assume its the speedo cable, how do I get it out?
Ozz
I think I have a problem here.
3,514
66
109
Canton, MI
Feb 26, 2004
  • Feb 26, 2004
Notice the front-most part has a clip. It retains the connection to the gauge cluster. Push down on the top of it (the white/offwhite connector part) and it will release the connection. Just push the top down, that's all you need. Once you get it off, you will see how it was connected. Now when it's pushed in, just yank the cluster towards you and it will come off.
G
gt90stang
568
  • Feb 26, 2004
First time I removed the cluster the speedo cable came out no sweat....didn't realize that you just squeeze the white part between the end and metal part to release the lock. Don't try and force it or you'll break it.
The second time I had a lot of trouble until I realized to just grab ahold of the white part and squeeze, then lightly pull the cable out. It should be easy, don't force it.
Good Luck, Don
BlownStangGT
REPEAT
3,860
Lancaster, PA
Feb 26, 2004
  • Feb 26, 2004
Where and how do I push down? Do i push in to make it smaller then ull it out?
BlownStangGT
REPEAT
3,860
Lancaster, PA
Feb 26, 2004
  • Feb 26, 2004
I got it!!! Thanks for the help!
87gtconv
ragtopman
2,595
Southern Calif
Feb 26, 2004
  • Feb 26, 2004
anyone know how I take the plastic off to get at the cluster??
SLiM JiM 156
1,024
Rohnert Park, CA
Feb 26, 2004
#10
  • Feb 26, 2004
  • #10
you just unscre the two screws on top, two screws on the bottom, pull off the colum plastics, pull out the light swtiches, and it comes right out
87gtconv
ragtopman
2,595
Southern Calif
Feb 26, 2004
#11
  • Feb 26, 2004
  • #11
Cool thanks will do this project this weekend took a fast look and could not see screws but if they are on top I will find them. I bought a new 140 m0h speedo and want to get it into my car asap!
Ozz
3,514
66
109
Canton, MI
Feb 26, 2004
#12
  • Feb 26, 2004
  • #12
It's held on by torx screws but you can't get to them until you take the entire thing out of the car.
Start by taking the steering column covers off, then the bottom dash cover, then remove the light switches from the dash, remove the dash, THEN remove the cluster w/the clear lens attached. It comes off with torx screws too, then you can take the lens off w/the same torx bit. It attaches in the same way, just in reverse.
Cammed90Notch
592
Greenville, SC
Feb 26, 2004
#13
  • Feb 26, 2004
  • #13
first time I was removing the cluster (heater core swap ) it took me 4 hours, and a phone call to Ford (which didn't help) to get it loose
BlownStangGT
REPEAT
3,860
Lancaster, PA
Feb 26, 2004
#14
  • Feb 26, 2004
  • #14
yeah, I got it all loose, dash and everything is out...only thing left interior wise inmy car is 2 front seats, carpet, and headliner haha, its all going black
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
J
Electrical Cluster bulb LED swap gauges bounce
  • jpfox
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
gkomo
P
Electrical 1988 GT Wrong Cluster- causing electrical issues?
  • pindude80
  • May 6, 2025
Fox 5.0 Mustang Tech May 6, 2025
pindude80
P
W
FoxBody Gauge Cluster - What would you pay?
  • wildstang17
  • Jun 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 26, 2025
Mustang5L5
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
