  • 1994 - 1995 Specific Tech
pully kit
  • Thread starter Thread starter howiefisher
  • Start date Start date Jun 26, 2007
howiefisher
154
Ont Canada
Jun 26, 2007
  • Jun 26, 2007
I AM BUYING A PULLY KIT 3 OF THEM ALT,CRANK,AND WATER PUMP ,HOW MUCH HP DO YOU GUYS THINK I WILL GAIN??I HAVE HEARD 10-15 HP
R
red95gtconvert
382
Ponca city, OK
Jun 26, 2007
  • Jun 26, 2007
I am not a human dyno but the gains were there.
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Jun 26, 2007
  • Jun 26, 2007
I felt a little boost in power.
But I took them off about 8 months later because I got tired of the constant charging problems.
Dino Dino Bambino
1,673
90
79
Cyprus
Jun 26, 2007
  • Jun 26, 2007
HP gains with underdrive pulleys are rpm-dependent and they also depend on what other mods you have. On an otherwise stock 5.0, the gain is something like 3-4rwhp. On a highly-modified 5.0 you might see a 10-12rwhp gain.
go-stang5.0
2,244
Glenview,Il
Jun 26, 2007
  • Jun 26, 2007
well to be exact as rpm increases hp from pulleys will increase. So you will only see more gains on a modified motor (vs. stock) if you spin it up to like 5 or 6 grand or more. But if you have a mild modified setup that makes power in the stock powerband than you wont see any gains over a stock motor w/ pulleys.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 26, 2007
  • Jun 26, 2007
For years now, peeps have time slips showing 1 to 1.5 tenths reduction
in 1/4 mile et times and in rare cases, some have found 2 tenths
The old 1/4 mile rule of thumb is 10 hp is good for a tenth
so
If you found 1.5 tenths that would be around 15 at the crank
and
Somewhere around 12.75 at the wheels using 15x.85
I been running them for quite some time with no probs what so ever
I do idle at 850 to 900 and that increased rpm helps with
charging issues at idle.
Grady
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
  • Mindseye007
  • Aug 16, 2026
Mindseye007
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
