PULLY KIT ???
howiefisher
154
Ont Canada
just installed pully kit now dash lights are running dim and volt gauge is 11 to 11.5 volts while running i no thats low i changed alt,crank,and water pump pullys is there any thing i can do to make it go back to 14 volts while running or is it just the pullys or will it heart my car or altanator?
Here is a little tip ... just for you my friend :D
Before you hose around with your tb blade stop screw
Just stick a feeler gauge, thin washer, dime, etc between the stop
and screw.
That will tell you right quick what is gonna happen without hosing up
the adjustment on your tb.
It might not be a bad idea to keep track of how many turns you
change that screw in case you wanna return back to its original
position.
Grady
