  • SN95 4.6L Mustang Tech
Pulsing/ Jerking In drivetrain under Accel..
  • Thread starter Thread starter 281reasons
  • Start date Start date Nov 25, 2006
1 of 2 Next Last
281reasons
12
Newtown, PA
Nov 25, 2006
  • Nov 25, 2006
My 01 GT has just started Pulsing under light acceleration
and Jerking or bucking under hard acceleration...
I've already done the following to try and fix the problem...
Replaced All 8 Spark Plugs,
Replaced all 8 Injectors,
Replaced Fuel Filter
Flushed the fuel system twice,
Tested all the Coils,
And cleaned the MAF.
What do I do Now? The problem is really getting very annoying...
I Don't know what else to do..
Help!! Thanks,
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Nov 25, 2006
  • Nov 25, 2006
does it do it in every gear or 5th only, just trying to get more info
CobraRed_96_GT
1,421
UCSD/La Jolla
Nov 25, 2006
  • Nov 25, 2006
sounds like a tranny problem, does it make noise too?
281reasons
12
Newtown, PA
Nov 26, 2006
  • Nov 26, 2006
No noise. and it's not a tranny problem...
already checked...
Almost like it's a crank positioning sensor or somthin... but it's not throwing codes...
does it in every gear.
again... I'm at this point...
blubullett
535
Modesto, CA
Nov 26, 2006
  • Nov 26, 2006
did you check for broken motor mounts? I had ove broken and while trying to idle around parking lots it would buck a little bit. Put in polyurethane mounts and its fine now.
DTNODYA
831
  • Nov 26, 2006
Replace your spark plug wires. I've been there .....
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 26, 2006
  • Nov 26, 2006
There are no spark plug wires.
O
OneStiffGT
87
Canada
Nov 26, 2006
  • Nov 26, 2006
did you check the reading you get from your TPS?
Brute03
232
  • Nov 27, 2006
i'm in the same boat as you, i did everything you did and my car still jerks and bucks
281reasons
12
Newtown, PA
Nov 27, 2006
#10
  • Nov 27, 2006
  • #10
Well I found what looks to be a pinched fuel line..
I'm going to straighten it out and see if that helps...
DTNODYA
831
#11
  • Nov 27, 2006
  • #11
I did not know that.
04GT
284
Southwest Ohio
Nov 27, 2006
#12
  • Nov 27, 2006
  • #12
I had a similar problem that turned out to be a fuel pump.
gtsr281
#13
  • Nov 27, 2006
  • #13
I had that problem and later installed the transgo HD shift kit. It has now gone away, it's more likely to be tranny problem. The AODE 4R70W is a ****ty trans. I blew mine out three times so now i got the T-56 6 speed HD.
281reasons
12
Newtown, PA
Nov 27, 2006
#14
  • Nov 27, 2006
  • #14
It's not a trans problem... def fuel...
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Nov 27, 2006
#15
  • Nov 27, 2006
  • #15
Yep I've had the same problem in other cars and it was the in-tank pump. PITFA to change, too.
Killy, No spark plugs??? ¿Qué?
stangGT97
1,299
Boston area, MA
Nov 28, 2006
#16
  • Nov 28, 2006
  • #16
Out of curiosity, does a fuel pump gradually start to fail or is it an off/on kind of thing? Also, does a failing pump make a lot of noise?
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Nov 28, 2006
#17
  • Nov 28, 2006
  • #17
With me, it usually started to fail gradually.
stangGT97
1,299
Boston area, MA
Nov 28, 2006
#18
  • Nov 28, 2006
  • #18
and what were your symptoms? loss of power, bucking?
281reasons
12
Newtown, PA
Nov 29, 2006
#19
  • Nov 29, 2006
  • #19
Well the good news.. Found the problem...
Crushed fuel supply line.
Which explains why it bucks under accel and is fine during cruissin...
Only problem is that I'm pretty sure my shop, the one who fixed the rear end damage, caused this crushed fuel line.... in the front of the vehicle, just before it goes into the wheel- well...
looks like somebody tried to lift the car in the wrong place with a lift pad, and in doing so, put a perfectly stright bend in the line...
How Nice... 160 dollar fuel line... Now I have to miss more work just to bring the car back to them, to have them take a look at it...
sorry for the little rant but, just had to get it off my chest....
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Nov 29, 2006
#20
  • Nov 29, 2006
  • #20
well glad you found the problem but sucks it costs you a bunch of coin.
1 of 2 Next Last
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
  • Gulftown980x
  • Jul 29, 2026
squeak93
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
