  • SN95 4.6L Mustang Tech
Put my c springs in yesterday!!
  • Thread starter Thread starter slvrbullIT
  • Start date Start date Nov 14, 2005
First Prev 2 of 2
slvrbullIT
635
Dallas, TX
Nov 16, 2005
#21
  • Nov 16, 2005
  • #21
i just went out and measured and it dropped the front a 1/2 inch from removing the top isolators.
ponysarepretty
578
#22
  • Nov 16, 2005
  • #22
Except for a bad ride quality, what are some other bad effects of taking out theisolators? Anything really bad gonna happen to the suspension?
slvrbullIT
635
Dallas, TX
Nov 16, 2005
#23
  • Nov 16, 2005
  • #23
i didnt notice a bad ride quality, it rides just the same to me. the only thing it might be worse on is if you hit a really big pot hole. i dont think its bad to not have them, the factory just puts them there to damp the springs a little.
ponysarepretty
578
#24
  • Nov 16, 2005
  • #24
any other views... i'm getting springs and thinking of how much I need to lower them.
M
m99GT
32
#25
  • Nov 16, 2005
  • #25
ive got steeda sport springs mine looks just like that(stance wise)
TrueBlue03
372
Bay Area, CA
Nov 16, 2005
#26
  • Nov 16, 2005
  • #26
how difficult is it to take them out. Dont you just take apart everything just as if you were swapping springs? I really want to take out my front isolators, but i know nothing about suspension and i was gonna take it to the shop to do it, but they'll just charge me the price of front spring installation right? and thats a lot of money just to take out little tiny isolators. I wanna try to do it myself...
could i do this at home with just a jack and some common tools? and does anyone know where i can get some good directions on how to do this?
TrueBlue03
372
Bay Area, CA
Nov 16, 2005
#27
  • Nov 16, 2005
  • #27
anyone?
jeffnoel
1,638
Clovis, CA
Nov 17, 2005
#28
  • Nov 17, 2005
  • #28
Spring Install How to
slvrbullIT
635
Dallas, TX
Nov 17, 2005
#29
  • Nov 17, 2005
  • #29
its not that hard, i took them out in about 1 hour. here is what i did: 1)jack up one side and put a jack stand on the frame then remove wheel 2)now remove the brake caliper by removing the two 12mm bolts in back and also free up the brake line by letting it out of its clip 3)put your jack under the a-arm and jack it until the strut just starts to raise, to support the suspension 4)remove the 15mm bolt that holds the swaybar endlink(the thing with the green bushings) 5) remove the strut bolt with a 13/16 inch open end wrench and i used a crowbar to wedge in the top slot of the bolt to keep the strut from spinning 6)after you remove the strut bolt you can lower the jack under the a-arm and the strut will come down with the a-arm and i just spun the spring around until i could get the isolator out 7)enjoy your lower ride
First Prev 2 of 2
L
A/C doesn't work after long drive
  • lking78
  • Jun 23, 2026
  • SVT Tech Forum
SVT Tech Forum Jun 30, 2026
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
  • Gulftown980x
  • Jul 29, 2026
squeak93
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 29, 2026
ejscarfo
E
