Putting a balancer on-
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
So if I get this straight - to put a professional products dampner on, I just take the belt off, unbolt the crank pulley, unbolt the balancer, take it ou, slide the new one on (it should only go on one way) bolt it down, bolt the crank pulley on and its as simple as that?
If I need a spacer, I guess I'll be able to tell. If I dont, do I keep the ring on it?
There's a kit - installer and puller in one. It was 80 bucks to loan out from CSK (fully refundable).
Be sure you remove the washer behind the crank bolt before you try to remove the damper. I put neverseize on the interface before installing the new damper.
You might have to remove your Efan to have room for the puller.
Good luck.
Okay well last night we didnt really get anywhere. :)
We got the crank pulley off, the balancer/crank bolt we got off, but pulling the balancer off got us stuck.
At first we couldnt get it to move at all, we tried for at least 20 min before we realized that the puller was too big and that we were pulling against ourselves :)
We then had to put the crank bolt back in and push against that, untill we got to the point where we had to keep backing it out etc etc.
We were almost out but it was too dark out to continue.
I'll probably finish on sunday.
Thanks guys
Joe
I ended up having to pull the fan & radiator to get room to remove the balancer... went ahead and pulled the timign cover and replaced the gears while I was that far in :)
bought the puller for $30 at autozone, used the same nut in the puller to push the balancer on.
Well switched the balancers...and problem FIXED! WOOT.
MattTheBat83 said:
im currently putting together my new engine and my balancer's ring isn't pulled out as much as the one in the pic but it has cracks in it. should i replace it?
Unless you have reason to believe it has spun or is going to fail, there is no need to replace it. Cracks are somewhat normal to a degree.
billison said:
how do you see if a balancer is bad?
Although Hissen is correct :rolleyes: What your looking for is a wobble of any sort. Also if you time the car and your marks are off the balancer has "spun" around the rubber seal. Most of the time though if that has happened is also has the wobble so look for that. :nice:
