quadrant kit installation..
  • Thread starter Thread starter Thenemesis
  • Start date Start date Aug 25, 2005
Thenemesis
321
chuckletown, sc
Aug 25, 2005
  • Aug 25, 2005
hey, just got my kit in today and hoping to put it in tonight with the hope it isnt tuff thing to do is it? sorry but neither me or my dad has put one in or messed with fox bodys T5's and stuff lol were capable of doing it, just like to know if its tuff or just a matter of tightening some bolts lol
Jo_885o
422
Clint. Twp, Michigan
Aug 25, 2005
  • Aug 25, 2005
The clutch quad, if so have fun taking the old one off. way under the dash and you have to break the old one off just did it on my stang and it was a pita. But other then that went smooth.
Camaros4Life
In my own world
Aug 25, 2005
  • Aug 25, 2005
Its easy but like above sometimes the old one is a pain to get out due to you being upside down, cramped up under the dash. Needle nose pliers help out tremendously.
QDRHRSE
1,590
Palmdale, CA
Aug 25, 2005
  • Aug 25, 2005
It's a 1-2 hour job. I hope you're not a big guy. Getting in under the dash is the only marginally difficult part of the job. I usually slide the seat all the way back and lay backwards on my back, feet towards the roof, and get my head under the dash. If you are a really big fella you may want to consider removing the seat.
89lxsport50
550
Franklin Tennessee
Aug 25, 2005
  • Aug 25, 2005
It is not really that bad. The hard part is getting the stock one off, but there is a trick to it. Both the quad and pawl are held on by springs. If you take a small flatblade screwdriver and pop the springs loose from the metal brackets they will come right off. Go to www.maximummotorsports.com and look at their installation directions. It shows a good picture of the assembly out of the car. Do yourself a favor and remove the driver's seat before you begin. Also be careful when you pull the clips out, because they will go flying, and you need to reuse them. I used a tool that looks like an awl with the sharp end bent into a hook to pull the pins. I couldn't get them with the needlenose pliers. Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 25, 2005
  • Aug 25, 2005
If you are a big guy, plan on taking the driver's front seat out and laying a piece of plywood over the exposed seat mount studs. I have been told that it is much easier if you peel the carpet back from under the clutch pedal.
The clutch quadrant kit I used (FMS) was somewhat of a pain to install. This was because I had a real bear of a time getting the old quadrant out due to lack of clearance between the shaft that supports the quadrant and a bracket that was welded under the dash.
When you put the new quadrant in, the quadrant support shaft and the pin in the end of the clutch pedal MUST be absolutely parallel. Mine wasn’t and I ended up drilling the clutch pivot pin hole in the new quadrant slightly oversize to get it to fit.
The FMS cable has a steel ring with an ear with a hole in it on the firewall end of the cable. I pushed the ring flush with the firewall and drilled a hole through the ear and put a sheet metal screw in it to hold the cable in place – makes the whole thing easier to assemble & adjust.
The binding common to adjustable cables is often due to misplacement of the adjusting nuts on the fork end of the cable. Both nuts should be on the back side of the fork so that the domed nut faces the fork and the other nut serves as jam or locknut to the domed nut.
Have fun and keep lots of Band-Aids handy – you may need them.
8950HO
658
  • Aug 25, 2005
read the www.steeda.com quadrant installation instructions.
click,"about us",then "tech articles",then "double hook clutch quad".
I`ve never done this job personally yet,but they mention depressing the clutch pedal to the floor in some stock quadrant removal steps that I`ve never heard mentioned before.
Thenemesis
321
chuckletown, sc
Aug 26, 2005
  • Aug 26, 2005
K i got it in last night, got rid of my clutch problems in a snap.. the old cable was actually about to snap, it was all frayed and stuff i got the FMS kit since it uses oem stuff with it.. i just forget about the firewall adj if i wanna use it i gotta come back and take the thing off again lol anywho thanks guys
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Salvage/rebuilt title question
  • djj62478
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 2, 2026
DadLife0724
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
