question about 85 gt...
  • Thread starter Thread starter Foxfan88
  • Start date Start date Jul 12, 2005
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jul 12, 2005
  • Jul 12, 2005
If i were to buy an 85 gt and get rebuild it with some e7s off a 93 would it be more powerful, what heads are on the 85s anyway?
Also what could be done with a basic rebuild on an 85 motor to make it up to par woth the 87-up 5.0s??
rd
3,316
63
109
Ocean Springs MS
Jul 12, 2005
  • Jul 12, 2005
If I was doing that, I would go for at least some iron GT 40 heads, some aftermarket aluminum ones, or some performance ported units. By the time you change the valvesprings, have a valve job done, etc, in the stock heads or some E7's you will be $5-700 into heads, and you could have some much better ones.
The best way to go for performance with E7's would be the Thumper ported E7's, from Thumper on this site. He seems to have a very good porting process for these.
Anything less, and you would probably want more right away.
Hissing Cobra
798
Massachusetts
Jul 12, 2005
  • Jul 12, 2005
If I'm not mistaken, the E-5 heads are the same as the E-7's. It's the E-6 heads that were different.
MrKwik
1,008
Kansas City, Kansas
Jul 12, 2005
  • Jul 12, 2005
I believe the chambers on the E5's are larger than the E7's so if you put E7's on the 85 block it will have more compression. Other than that I think they are the same. I have heard some poeple say that 85's had dished pistons but my 85 motor has flat tops, not flat tops like an 86 but regular old flat tops with 4 valve reliefs. So with that in mind, I would assume that an 85 block with E7 heads would have more compression than an 87-93 and maybe a few extra horses. I wouldnt swear to it but thats pretty much what my research on the subject has shown.
V
v8only
2,378
22
49
Jul 13, 2005
  • Jul 13, 2005
pretty much, an 85 engine IS up to par power wise with the 87 engines. TO get more power, put a better carb and intake on it, then ditch that choked down single exhaust y pipe for a true 86+dual h pipe. That should get you past the hp level of an 87+
everyone seems to agree that for the work involved you'll essentially see almost no difference in power between the e5 heads and e7 heads, they're just too close to each other. Like mentioned, pull some gt40's off an explorer, then you're talking about a "real" upgrade.
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Thursday at 10:40 AM
AeroCoupe
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
