  • 1994 - 1995 Specific Tech
question about my smog removal
  • Thread starter Thread starter trav_19
  • Start date Start date Mar 11, 2007
trav_19
810
Jackson, MI
Mar 11, 2007
  • Mar 11, 2007
well my bay is getting a healty dose of dieting lol i have gotten to the smog/egr and i have a few questions the tube from the back of the heads and the tube coming up from the h pipe they run together for a second if i remove everything up to the hard lines then cut them right before they both go down...i was wondering how much pressure these are forcing.....because at my dad's auto parts store they have this two part clay that when you work between you fingers it mixes the two parts and then forms a extremely hard compound its rediculous... if for now i used it to plus the two tubes right there do you think it would be a problem ?? in the spring when i can get the car to a friends with a lift i will do the h pipe tube right and when i get someone to give me a hand i can probley remove the tube behind the heads....but i want them out now because im going to be doing plugs and wires and it would be so much easier to remove all that crap so do you guys think it will work??
95opal
5 Year Member
Nov 16, 2004
449
20
39
Mar 11, 2007
  • Mar 11, 2007
You should be able to take the cross over off the heads and just plug the holes with a 9/16 bolt. Just crimp the litte tube on the h-pipe real good and maybe a little JB and your good to go.
trav_19
810
Jackson, MI
Mar 11, 2007
  • Mar 11, 2007
it looks like a real tight fit behind the heads you dont think anything will seal the tube up and work??
bill302
2,131
alabama,gadsden
Mar 11, 2007
  • Mar 11, 2007
very easy to do just follow the step by step instructions in the link below as i did when i removed mine...
http://www.allfordmustangs.com//techarticles/Smog2.pdf
trav_19
810
Jackson, MI
Mar 11, 2007
  • Mar 11, 2007
everytime i try to click the link it begins to open then pops up error on page then it closes down my internet
bill302
2,131
alabama,gadsden
Mar 11, 2007
  • Mar 11, 2007
you need to download adobe reader 7.0
http://www.adobe.com/products/acrobat/readstep2.html
Cobra4075
286
Tinley Park, IL
Mar 12, 2007
  • Mar 12, 2007
I couldn't find a 9/16 bolt that short. I usede a helicoil first reducing it to a 1/2'' and then plugged it. A dab of high temp silicone on the threads helps also.
trav_19
810
Jackson, MI
Mar 12, 2007
  • Mar 12, 2007
i downloaded it and still wont work for me i give up....i think i will just try this putty stuff and hope it holds under the pressure
Fox Removing smog only questions
  • 91GTstroked
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
91GTstroked
Y
BBK SSI Crossover tube
  • yaboity
  • May 17, 2025
1994 - 1995 Specific Tech Jun 7, 2025
yaboity
Y
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
