question about ring orientation
old_blue
1,783
282
124
buddy and I are disagreeing about where the ring gaps go on the piston. actually there are three of us having the debate.
here are the options-
1: all rings are to be alternated 6 oclock then 12 oclock
2: only the oiler and the the adjacent (rings directly above and below) need to be alternated. the top and bottom cna be whatever
3: set the oil ring and the two rings above and below it gapped at three different positions then the top and bottom rings 180 deg different.
Here is a diagram of what I am talking about.
In the diagram, "A" is the Oil Ring Spacer Opening
"B" is the Oil Ring Rail Gaps
"C" is the second Rings Gap
"D" is the Top Ring Gap.
Also note the orientation of the piston in the block.
In no way should any of the ring gaps overlap another.
I did mine over the winter, and I have perfect circle brand rings that came with these instructions that I used:
"A" is the Oil Ring Spacer Opening (position not used)
-*more like 11 oclock close to the left side "B" should be bottom oil ring gap;
-but right side "B" is the starting position for the expander, the ending range for the expander is like "5 oclock" this position is not that critical- I personally used the right side B location exactly.
-the 7 oclock position should be the top oil ring gap
"C" is the second Rings Gap +1
"D" is the Top Ring Gap. +1
photodisplay.php
