question about tachometer
  • Thread starter Thread starter brtnstrns
  • Start date Start date Jun 10, 2006
brtnstrns
606
11
Lewisville, TX
Jun 10, 2006
  • Jun 10, 2006
So I've had my tachometer hooked up for a while and it used to work fine but now it just sits at about 7000 rpms and doesnt move. Very rarely it will work when I turn the car on and then when i turn it off and turn it back on it will stay at about 1000 rpms then roll backwards to 7000 rpms and just stay there when the car is on and when the car is off. Anyone have any ideas of what the problem is?
Cobain03
996
Lexington, Ky
Jun 10, 2006
  • Jun 10, 2006
maybe it was installed in a civic and the owner pushed it to 11 thousand rpms and broke it. lol
mine is starting to jump at higher rpms as well ( above 3500)
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Jun 10, 2006
  • Jun 10, 2006
What kind of tach is it? Stock, Autometer, VDO, Sun, Stewart Warner, Shelby repro, etc?
It sounds like an internal fault, a short somewhere, or something broken.
brtnstrns
606
11
Lewisville, TX
Jun 11, 2006
  • Jun 11, 2006
its an autometer tach
D
DJCarbine
392
  • Jun 11, 2006
I had a similar thing happen to a SUN tach. Take the tach loose if its easy. Open the hood and hook it up directly to the battery, and tap right into the coil. If it still behaves erratically, then its a tach problem. If not, it was teh same problem I had. A combination of a poor ground, and a "dirty" power source. (mine would jump up and down 2,000 RPM in tune to the turn signal blinks )
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Fox Turn signal flasher keeps failing
  • keel
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
