question about the victor 5.0
I think you can run it if you are using a EGR spacer with the TB. If you are not running EGR spacer and use the throthle cable bracket I think it would be a tight fit and not work.
What I do with mine is get a adapter fitting for the intake hole to the sensor and stick the sensor directly in the intake removing the rail. This reducer fitting can be found at any hardware store.
