question about zddp additive
  • Thread starter Thread starter Markus
  • Start date Start date Nov 18, 2011
Markus
238
germany
Nov 18, 2011
  • Nov 18, 2011
Hello guys,
will hurt such a zddp (zinc) additive o2 sensors
thank´s
Markus
rbohm
6,698
550
204
tucson,az
Nov 18, 2011
  • Nov 18, 2011
that is the reason zddp is being slowly eliminated from modern lubricating oils, it coats the O2 sensors rendering them in the end useless.
Markus
238
germany
Nov 18, 2011
  • Nov 18, 2011
i thought it kills generally catalysts by a chemical raction
65coupe408w
192
  • Nov 18, 2011
who needs O2 sensors anyway...
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
Nov 18, 2011
  • Nov 18, 2011
That's right, real Classics don't need no steenkin O2 sensors!
Hack
1,945
Minneapolis
Nov 19, 2011
  • Nov 19, 2011
It shortens the O2s life, but not dramatically. Unless you have bad valve guides or a worn out engine I wouldn't worry about ANY impact on O2 sensors life. There were many, many years of EFI engines that ran using oil with ZDDP in it. The reason for eliminating it in oil is not so clear to me. When the government says things that don't make a lot of sense to me I start thinking about the money trail.
Things like, "oh those cheap light bulbs that last for years and years are bad for the environment, but these mercury-filled bulbs that cost $6 each are much better for the environment."
Bastards.
Markus
238
germany
Nov 20, 2011
  • Nov 20, 2011
Bastards.
Hack,
thank you for the qualified answer
Markus
Realmongo
2,466
86
99
Western Mass
Nov 20, 2011
  • Nov 20, 2011
Are you running a flat tappet camshaft with fuel injection?
Markus
238
germany
Nov 20, 2011
  • Nov 20, 2011
No, hydraulic roller
Realmongo
2,466
86
99
Western Mass
Nov 20, 2011
#10
  • Nov 20, 2011
  • #10
I went with a roller block when I replaced the original engine in the '84, so I do not have to worry about haing to use an additive in that car. Shell has released a 10W-30 version of Rotella that meets the older SM rating that I am using in the 64-1/2 and 65 engines with flat tappet cams that require the protection the roller engines do not. The biggest concern of damage from the additive is to the catalytic converters.
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Thursday at 4:37 PM
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
J
O2 sens
  • JJ's90fox
  • Sep 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2025
Mustang5L5
