OK, know I have made MIl eliminators and sequential tailights is it possible to MAKE a traction control mod that would turn that crap off on startup and be able to turn it on when needed
THAT WOULD BE SWEETSpazilton said:I should buy one then break it down and post how to make your own![]()
Great, I am interested to see this.MachInegun said:I just made one using a 556 IC and R's/C's and diodes. When it gets power (key ign) it delays 5 seconds then sends a 1 sec 12v to the ECU. About $10 in parts from RatShack.
I'll see about getting the schematic.....
do you connect the 12 v sig to the Gray wire?MachInegun said:I just made one using a 556 IC and R's/C's and diodes. When it gets power (key ign) it delays 5 seconds then sends a 1 sec 12v to the ECU. About $10 in parts from RatShack.
no, the button just makes momentary contact. It is not like an on/off switch you are3 thinking of.merc123 said:Could you not reverse the switch?
Slider said:The PEP unit cannot be easily duplicated. Unlike the $10 radioshack unit, the PEP unit has memory. That means that it remebers on startup what the last setting was. If you are at the track or the weather is nice you can set the trac ctrl on startup to default to OFF. However, if the weather is bad or someone less experienced with the your car (i.e. girlfriend, wife, friend) is driving it, then you can set the trac ctrl to default to ON. Though it seems like a lot of money at first, the unit really pays for itself over the long run. I have one, and I find it to be an invaluable accessory for my car.
