Question on Junkyard rearends
  • Thread starter Thread starter 04mustang70
  • Start date Start date Jul 14, 2008
04mustang70
88
Twin Lakes, WI
Jul 14, 2008
  • Jul 14, 2008
I have a 28 spline open rear end with 3.00 rear gears. I would really like a posi with 3.50 or so gears. Can I find one in a junk yard? What other vehicles most likely came with gearing like this?? Will any 9 inch center section with 28 spline work on my 1970 differential? Do I have to look for any specific year rearend to just bolt on to mine? Is there any good rearends in junkyards? As you can see I have no clue. Thought I would ask before I go blindly into see the junkman. Thanks in advance
calpolymustang
217
Santa Rosa, CA
Jul 14, 2008
  • Jul 14, 2008
Kevinstang's Ford Nine Inch Differential Page +
Ford 9 Inch Rebuild/Gear Setup .: Articles
A few things to note:
The nodular case is hard to find, but worth $$$. If you get the WAR case, it wont be as strong (more brittle casting).
In my experience, many rear ends have different mounting arrangements, so plan on buying new perches and welding in new ones to match your leafs.
I bought a Lincoln Versailles rear for $350 then sold it for $750. people are paying a lot for em if they have ALL the emergency brake hardware. By the way, this one had 2.73 gears with a 4-pistion trac-loc. You will need a new yolk for the 3rd member if you go with a rear end that has a flat flange that mounts to the driveshaft. Most hot rodders use a yolk that bolt directly to the u-bolts, with no flat-flange.
Hope this helps...
D
D.Hearne
11,730
south louisiana
Jul 15, 2008
  • Jul 15, 2008
It'll be almost impossible to find a 28 spline 3.50 geared 9" rear in a junkyard, it was 20 years ago as well. Any 28 spline 9" chunk will work in yours. It's realitivly easy to find a 3.50 geared 9" chunk with traction loc, but it'll be a 31 spline unit. Just look under the big Bronco's. That's where I found mine. 81 Bronco. The 4wd's pickups and Broncos usually got trac-loc rears. Some 2wds too, just not as many. Cars with 9's seldom got trac-loc rears. I've had three Lincoln Versailles 9's (one actually came from under a 78 Monarch) out of these three only one had trac-loc and that was the Monarch rear.
bnickel
5,640
lubbock, texas
Jul 15, 2008
  • Jul 15, 2008
the big bronco 31 spline rear will work just fine, especially if it's a trac loc, you will have 2 options if you go this route. option one would be to change the side gears in the trac loc unit to the 28 spline units which is not difficult at all, option two would be a good excuse to upgrade to 31 spline axles.....you can get them from some places for around $150 for the pair brand spankin' new......
EDIT: sorry, the axles were actually $150 each
http://store.summitracing.com/egnse...94851288+4294908331+4294925081+115+4294908282
66blue mustang
66
N. AL
Jul 15, 2008
  • Jul 15, 2008
i got my 8" rearend with 3.55 posi out of a mustang II.
D
D.Hearne
11,730
south louisiana
Jul 15, 2008
  • Jul 15, 2008
The Strange Axles I bought for the Comet were $400+ for the pair.
bnickel
5,640
lubbock, texas
Jul 15, 2008
  • Jul 15, 2008
superior 31 splines for $150 each
Axle Shafts, Direct Fit - summitracing.com
D
D.Hearne
11,730
south louisiana
Jul 16, 2008
  • Jul 16, 2008
Yea, Superiors are a better price, but if you've got a non stock axle width.............
bnickel
5,640
lubbock, texas
Jul 16, 2008
  • Jul 16, 2008
they also sell non stock widths as well, same price i think with an additional 15 bucks per axle to cut them to length
jlangholzj
Mustang Master
Oct 23, 2006
248
31
93
MI
Jul 16, 2008
#10
  • Jul 16, 2008
  • #10
how much would it be to change out the side gears on the trac loc to 28 spline?? I've been debating this very same question myself.
same setup, only in a 68 : 3.00, open, 8"
bnickel
5,640
lubbock, texas
Jul 16, 2008
#11
  • Jul 16, 2008
  • #11
if you think you can do the work yourself just the cost of the side gears and axles and of course all the stuff that goes along with it like bearings, seals, etc.
D
D.Hearne
11,730
south louisiana
Jul 16, 2008
#12
  • Jul 16, 2008
  • #12
An 8" rear's already got 28 spline axles. And a 9" chunk won't fit anyway. You'd have to get a whole 9" for Stang first
D
D.Hearne
11,730
south louisiana
Jul 16, 2008
#13
  • Jul 16, 2008
  • #13
Wish I'd known that a year ago.
bnickel
5,640
lubbock, texas
Jul 16, 2008
#14
  • Jul 16, 2008
  • #14
sorry, i thought you were asking about changing the 28 spline 8" trac loc over to 31 splines. it can be done using the 9" trac loc 31 spline side gears and the correct axles. wonderful thing about the 8" and 9" is that a lot of the parts are interchangeable
jlangholzj
Mustang Master
Oct 23, 2006
248
31
93
MI
Jul 16, 2008
#15
  • Jul 16, 2008
  • #15
Maybe I'm blunt, but these seem to be conflicting here.
but a 9" chunk wont fit in the 8" housing huh?
ultrastang
1,092
Arkansas
Jul 16, 2008
#16
  • Jul 16, 2008
  • #16
It is true that the 28-spline axle gears from a 9-inch differential can be swapped out for 31-spline gears, but in the case of an 8-inch rear end, 31-spline axles won't work in them because the opening of the stock 8-inch differential [on the ends where the differential bearings press on] don't have a large enough bore for a 31-spline axle to fit into it.
Just to reconfirm, I took a Traction-Lok 3.00:1 8-inch 3rd member I have from a '76 Mustang II and tried to slide a 31-spline axle into the differential, but it wouldn't even get past the very outer opening going into the differential casting.
bnickel
5,640
lubbock, texas
Jul 17, 2008
#17
  • Jul 17, 2008
  • #17
i've known dirt track guys here who have made up 31 spline 8" diffs around here and was told that all they did was swap the side gears from the 9" diff over the the 8" diff. i've also verified tht these same guys were running 8" diffs. now whether or not the 8" diffs actually had 31 spline axles as they said i can't say, i just took them for their word, i suppose.
also, the guys at Autoworks Intl. that built the Dynacorn Phantom car used a 31 spline 8" in that build as well.
point is that i know it can be done and it has been confirmed that it can be done, maybe it's just more involved than just swapping the side gears as i've been told previously though.
ultrastang
1,092
Arkansas
Jul 17, 2008
#18
  • Jul 17, 2008
  • #18
I've heard of some 31-spline axle being installed into an 8-inch rear, but I suspect it its not a stock, Ford-produced, differential(?)., or the differential's I.D. [where the axle slides in to engage the axle gears] has been bored out oversized in order to get the axles to go in(?).
In the case of the 8-inch 3rd member & 31-spline axle I have, the axle would not go into the differential at all, so that makes me wonder if the differential they are using is an aftermarket item, or if it's a stock modified unit?
On the 9-inch differentials, the bore is large enough to handle either 28- or 31-spline axles without the need for mods to the differential, other than swapping the axle gears out themselves.
Will I feel a difference
  • 90Stanger302
  • Mar 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 13, 2026
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
