Question on roller cam installation
Is it a MUST to change valve springs and rocker arms when installing a E303 Ford Racing Cam into a 94 5.0 ?
A must. No.
A waste of time if you don't, probably.
I would imagine your valve float is minimal with the stock cam, but with the E303 you will start to see it, and depreciate your springs in the process.
JMO, wait and see what others have to say.
Scott
A must. No.
Scott
i agree
with old, stock springs and a much higher lift youll probably see some valve float
and since your going through the trouble of a cam swap i would change the springs.
The stock springs are barely able to contain the OEM setup :eek:
These days ... all OEM parts are designed that way :bang:
Having said that .............
You got two things to consider IMHO :D
1) The older your OEM springs ... the weaker they have become
2) The new cam is gonna work those OEM springs harder
and
If they don't do the job of containing the VT now ........
Its most likely gonna happen pretty quickly if you don't upgrade
I'd change em out :nice:
besides
Its easier to do heads off rather than heads on ;)
Grady
