Questions about Performer RPM -
SiK91LX
78
SF, CA
Hey i just installed the Edelbrock Performer RPM Intake and idont know where to run the vacum lines to? The stock has a plug underneath the intake so i can jus connect it to but the RPM doesnt... Also what about the fuel pressure line? Other lines?
Thanks, pics would be good also!
Thanks
i have that manifold on the new motor. i bought used so i had no directions, but i just figured, everything that needs to see direct manifold vacuum, hook up to the manifold. everything that just needs vacuum, hook to the tree. so my fuel press. comes from the tree. i just used like 3 lines at most from the manifold, plugged everythign else. it runs just fine. you'll be allright, just hook em up and go, theres not really any vacuum regulators so to speak, reducing vacuum to any thing that sees vacuum, so you should be allright just hookin up.
I gave up so bad ii took it to a shop and they said to pick it up monday.........if they dont have it done ima pick up the car and transfer all stock lines on it and see how does..
My car wouldnt even stay on - kept dyin on me ....
