  • 1994 - 1995 Specific Tech
Questions
  • Thread starter Thread starter 95mustang_gt
  • Start date Start date Aug 12, 2005
9
95mustang_gt
364
Wisconsin
Aug 12, 2005
  • Aug 12, 2005
I was wondering if i can take the bar off that is by the intake.im not sure whats it called.i think it is the strut bar.Also where is that 25lb weight that i hear about.i heard its by the fog lights.Anyone got a pic?
a_k
170
Saratoga NY
Aug 12, 2005
  • Aug 12, 2005
don't take it off, it stiffens the front of the car. you should also take off your air pump if you are running an off road h pipe. Saves weight and it's one less thing turning.
CManT1914
3,172
Killeen, Texas
Aug 12, 2005
  • Aug 12, 2005
You can take both off. I had to lose mine when I did my cobra intake, and noticed no difference in handling. I'm sure an aftermarket one helps out, but the stock one seems to not do much.
The fender weight is directly above the passenger side foglight. It has two bolts (I think) that hold it in place. You can lose this as well. Just be careful if you take it off to not drop it on your forehead when you take the bolts out.
DFG 5OH
1,341
Louisville, KY
Aug 12, 2005
  • Aug 12, 2005
the 25 lb weight is only on verts, and i took off my strut and noticed NO difference, cept the front coming up more when i take off.
sage2k
645
Baton Rouge, LA
Aug 12, 2005
  • Aug 12, 2005
Whats easiest way to remove that 25lb weight? Get under? Do i have to remove fog light to get at it? How much does the smog pump weight?
CManT1914
3,172
Killeen, Texas
Aug 12, 2005
  • Aug 12, 2005
Jack up the front of the car, you don't have to remove the foglight, in fact I don't think you can with the weight in the way. You'll be able to see it clearly, just feel around for the bolts that hold it in place, you'll find them. Like I said earlier, make sure to not drop it on your head like I did. You'll have a killer headache.
I haven't actually weighed it, but the smog pump is pretty heavy. I think it weighs around 20+ lbs by itself. Then you have all the pipes.
V8302stangs
211
San Jose, CA
Aug 12, 2005
  • Aug 12, 2005
What do you guys think of removing the smog pump as far as difficulty? I just smogged my car and plan on being able to smog again in 07. About to do a shorty header install and maybe I could just take care of the pump as well. In fact, I didnt even have the tube attatched to the h pipe when I had it smogged and it passed!
CManT1914
3,172
Killeen, Texas
Aug 12, 2005
  • Aug 12, 2005
Removing smog is super easy. Since you don't have the pipe hooked up it's even easier. Just remove the hose that runs from the heads to the pump, then you can pull the pump off itself. Then use a 1/2" (I think) wrench to get the bolts off the back of the heads. Soak them in PB blaster or liquid wrench first, then use the closed end, you don't want the wrench slipping off the heads. I had the whole smog assembly yanked in about 15 minutes. Don't forget to cap off the vacuum lines, there should be 2 if I recall correctly. Eventually you'll want to delete the smog system from the EEC using a twEECer or a chip or something.
V8302stangs
211
San Jose, CA
Aug 12, 2005
  • Aug 12, 2005
Did ya notice any hp difference after removing the smog junk?
CManT1914
3,172
Killeen, Texas
Aug 12, 2005
#10
  • Aug 12, 2005
  • #10
I did it at the same as my heads and cam, so I have no idea. It really won't free up a whole lot of hp, maybe a couple. Weight savings is the main thing it does.
95WhiteVenom
624
Alabama
Aug 13, 2005
#11
  • Aug 13, 2005
  • #11
take the crap bar off mine didn't come with one hehe i've drove several gt's and didnt notice a difference. you prolly wont either.
a_k
170
Saratoga NY
Aug 13, 2005
#12
  • Aug 13, 2005
  • #12
i didn't really notice anything taking off the smog pump, but why have it there you know? I'm sure there is a small power increase even it it be 1 or 2 horse max. the way I see it, every little thing helps
9
95mustang_gt
364
Wisconsin
Aug 13, 2005
#13
  • Aug 13, 2005
  • #13
taking the smog pump would it affect emissions?
CManT1914
3,172
Killeen, Texas
Aug 13, 2005
#14
  • Aug 13, 2005
  • #14
Only if you have catalytic converters.
RacerRick
20+ Year Stangneter
Jun 26, 2004
90
Ponchatoula, La.
Aug 14, 2005
#15
  • Aug 14, 2005
  • #15
I sometimes can't believe the poor advice I see here, if you are into handling with higher rate springs and such KEEP THE STRUT BRACE! You want the suspension to move not the strut tower (and it will flex some). Why do they sell so many chassis stiffening kits?? stiffer chassis=better handling! fact
P
Hello, core supports for '86 vs '90-3, i need some answers if anyone knows
  • Pony Dr.Mike
  • Mar 14, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 15, 2026
95steedamustang
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Monday at 4:00 PM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Monday at 8:58 PM
AeroCoupe
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
