Be sure to use the correct thickness of cable for your positive. For i made this mistake and my alternator wouldnt charge my battery properly. Also if you go under the carrage make sure to stay away from hot exhaust pipes, the drive shaft, or any area where the insulation could rub away and ground the positive out. Good Luck.
