  • SN95 4.6L Mustang Tech
Quick computer question...
  • Thread starter Thread starter trublustallion
  • Start date Start date May 11, 2009
trublustallion
386
El Paso, Texas
May 11, 2009
  • May 11, 2009
I have an Xcal3. I reflashed my computer after my gear swap, but my battery decided to kinda die . Do i have to reflash it, or will the tune still be there even after my car had no battery for like 5 hrs.?
Thank you mucho.:SNSign:
Flghtmstr1
572
Springfield, PA
May 11, 2009
  • May 11, 2009
I'm not quite sure I understand what you are asking. Did the battery die while you were flashing the the computer, or did it die later? If it died while you were flashing the computer, you might have trouble with that PCM. If it died afterwards, you should be fine.
The computer won't "forget" a tune if it loses power. It will, however, become corrupted if power is interrupted during the flashing process.
trublustallion
386
El Paso, Texas
May 11, 2009
  • May 11, 2009
My battery died the day after i flashed it. Thanks, that answered my question.
trublustallion
386
El Paso, Texas
May 11, 2009
  • May 11, 2009
Oops, double post
Skud
493
Saskatchewan
May 11, 2009
  • May 11, 2009
No, you will be Okay..
However, you need to be VERY careful when flashing the computer that you have a good, fully charged battery. If your battery dies in the middle of the flash you're SOL. You will most likely have to get the car towed to Ford to reflash the ECU or possibly a new ECU.
I always like to pull the fuses for the fuel pump and fan. They're in the power distribution box next to the battery. The fuel pump fuse is the left column at the top; it's a small fuse (20A I think). The fan is the middle column at the top. It's a big fuse (50A I think)..
Riley
J
Power Wire Upgrade Question
  • jhaling
  • Dec 21, 2025
SN95 4.6L Mustang Tech Mar 23, 2026
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
