Quick Fuel Question... Yes or NO
  • Thread starter Thread starter crunchie12268
  • Start date Start date Aug 17, 2004
C
crunchie12268
599
Manhattan, KS
Aug 17, 2004
  • Aug 17, 2004
Everybody says my combination is mild and that I don't need some things.. to get my car running better maybe I should take off my 24# injectors, 75mm Mass Air and Fuel Pressure Regulator... I am hoping that it will fix all the problems I am having. I will return to the stock injectors, stock mass air meter, and stock regulator... Will my stock regulator work with my 255lph fuel pump?
RydeOn
Licensed to Chill
6,273
orange county, CA
Aug 17, 2004
  • Aug 17, 2004
Putting this stuff on is part of suping up your car. There is a problem somewhere. Figure out what it is instead of going stock. Will your stock regulator work with your 255 pump? Yes it will. So whats the problem you are having?
blk92stangg
583
Hawaii
Aug 18, 2004
  • Aug 18, 2004
Hey crunchie, I remember you wondering about needing an adjustable regulator. If you post your problems maybe someone can steer you in the right direction.
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
Fuel Anyone know a part number for a 3/8" inlet/outlet efi quick connect fuel filter that would fit the stock foxbody location?
  • rednotch
  • Dec 8, 2025
Fox 5.0 Mustang Tech Dec 8, 2025
rednotch
  • Mindseye007
  • Aug 16, 2026
Mindseye007
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
