Quick Fuse Block question?
  • Thread starter Thread starter big_tiger15
  • Start date Start date Apr 1, 2005
big_tiger15
88
Arlington, Texas
Apr 1, 2005
  • Apr 1, 2005
How do I pull out one of the pins (or the contact where the fuse goes in) on my 91 Stang? I am replacing all the burnt up wires that deal with my dash lights. F-nut that had the car before has a 25 amp fuse on #13 which is a 5 amp
HISSIN50
34
129
Apr 1, 2005
  • Apr 1, 2005
i have not done it on a stang, but i usually like to unbolt the block and get at the back side. one can usually use a dental pick or tiny screwdriver to press the pin on the wire and pull it out. if you get some OEM style terminals, you should be able to put the new terminal back in the same way (which is imperative, since the fuse blade will try to push the terminal out the back, which could get to be real old).
in a pinch, i have bypassed bad connectors with a splice and inline fuse of the correct rating.
good luck.
Electrical Alternator not charging after terminator 2 install.
  • Sfab79
  • Aug 24, 2025
  • 2 3
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
  • dan50
  • Jul 18, 2026
dan50
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
A
Resolved 03 GT Parasitic Draw Fuse 26 (PCM)
  • Antrix
  • Mar 22, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 24, 2025
89ripper
