  • 1994 - 1995 Specific Tech
QUICK HELP with head gasket prep..
  • Thread starter Thread starter ShiftTheDrift
  • Start date Start date Apr 30, 2005
ShiftTheDrift
365
Bakersfield, CA
Apr 30, 2005
  • Apr 30, 2005
I'm ready to put my heads back on and I'm to the point where I don't know what I should do. Here are a few questions..
1) Do I need to apply sealent to the bottom of the head gaskets and on top? They already have this blue stuff on them.
2) My gasket kit came with several other gaskets. For instance, an o-ring, theses individual (looks like exhaust or intake port) gaskets and four other gaskets that look like they seal around the distributor and the back?
If necessary, where do I apply sealent and for both top and bottom?
(I have both Permatex black and copper sealent)
Thanks!
ShiftTheDrift
365
Bakersfield, CA
Apr 30, 2005
  • Apr 30, 2005
S/CBlack95GT
2,018
Tampa Palms, FL
Apr 30, 2005
  • Apr 30, 2005
Put nothing on the gaskets. The heads, block and gaskets should be super dry and clean. I use ARP moly lube on the long bolts and ARP thread sealer on the short bolts. I put the lube and sealer on the washer surface of the bolts as well. Then I torque them all to 65 ft-lbs.
ShiftTheDrift
365
Bakersfield, CA
Apr 30, 2005
  • Apr 30, 2005
What is the o-ring and the longer curved gaskets for?
S/CBlack95GT
2,018
Tampa Palms, FL
May 1, 2005
  • May 1, 2005
The O-ring is for the distributor and the long curved gaskets are the end seals for the lower intake. Just toss those in the trash though and lay a 1/4" bead of silicone in their place. The spots Im talking about are the ridges on the block, between the heads, in the front and the rear.
ShiftTheDrift
365
Bakersfield, CA
May 1, 2005
  • May 1, 2005
Gotcha.
One more thing, I was looking at my head gaskets and I've noticed that where it says front.. okay, BUT, there are two coolant holes that will be covered up. Is this right or do I have the wrong head gasket. I got the part number from TrickFlow's web site?
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
O
2000 Mustang 9000.00 in repairs
  • Onewitnessus
  • Nov 26, 2024
1996 - 2004 SN95 Mustang -General/Talk- Dec 11, 2024
caliber92
Help! Intake Manifold Gasket or Head Gasket?
  • foxbodyclark
  • Oct 4, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
95 Laser GT Ver
