Quick question about fuel line.
  • Thread starter Thread starter Hydrocarbon
  • Start date Start date Dec 9, 2004
H
Hydrocarbon
160
Medford Oregon
Dec 9, 2004
  • Dec 9, 2004
I need to replace both my feed and return lines. Can I use Summit's -8AN aluminum fuel line, or will it explode due to the EFI fuel pressure?
88 Fox GT
1,674
Iowa
Dec 9, 2004
  • Dec 9, 2004
Buy some of this, safer that aluminum or steel line and only $2.50 per foot. You could expect to pay $40-$50 for both feed and return line.
http://www.ronmorrisperformance.com...de=9130&Category_Code=Fuel_Fittings&Fuel_Line
H
Hydrocarbon
160
Medford Oregon
Dec 9, 2004
  • Dec 9, 2004
My exhaust guy said he won't install tail pipes if I use rubber (or nylon) hose near the axle. Plus I might need a larger line for more HP. As long as it doesn't burst or leak I can't see why it wouldn't be safe. If I get in an accident bad enough to break the hard lines, I'll be dead anyways.
88 Fox GT
1,674
Iowa
Dec 9, 2004
  • Dec 9, 2004
As for an accident, you SHOULD have an intertia switch. Do you? If so, it will kill power to the pump in the event of an accident.
The exhaust temps clear in the rear of the car are very low. Definitely way too low to melt these lines. The line also shouldn't be within a few good inches of the exhaust anyway. So I wouldn't even worry about that.
According to your signature, you have a pretty mild, nearly stock engine. I have all the most listed in my sig and the donor car (that I got the engine out of) was running stock line. It was plenty for the mods I've got.
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
Fuel Anyone know a part number for a 3/8" inlet/outlet efi quick connect fuel filter that would fit the stock foxbody location?
  • rednotch
  • Dec 8, 2025
Fox 5.0 Mustang Tech Dec 8, 2025
rednotch
Fuel 87 5.0 Fuel rail lines
  • Mcmahst
  • Jan 21, 2025
Fox 5.0 Mustang Tech Feb 11, 2025
Mcmahst
M
2000 mustang fuel feed tube
  • Mali
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 13, 2026
Mali
M
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
