quick question
  • Thread starter Thread starter warriorpluto
  • Start date Start date Oct 7, 2011
warriorpluto
267
monroe.LA
Oct 7, 2011
  • Oct 7, 2011
can i check compression with the lower intake off?
R
reldla1996
356
22
Dayton, Ohio
Oct 8, 2011
  • Oct 8, 2011
Yes you can.
warriorpluto
267
monroe.LA
Oct 19, 2011
  • Oct 19, 2011
Just tried it with and without push rods and rockers. The gauge just bounced up and down.really didn't go anywhere. Tried it on two cylinders
warriorpluto
267
monroe.LA
Oct 19, 2011
  • Oct 19, 2011
So do I have to place lower intake back on to get a proper reading?
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,081
224
Massachusetts
Oct 19, 2011
  • Oct 19, 2011
Did it bounce around at a certain pressure? That should be all does.
warriorpluto
267
monroe.LA
Oct 20, 2011
  • Oct 20, 2011
Never mind I got it to read. Didn't have the distributor in to circulate the oil. Compression results are
1:75
2:100
3:75
4:50
5:145
6:145
7:150
8:148
Forgot to put coolant in car on first start because was so excited to get running. Ran for six minutes in idle. Think blown head gasket or worse? Car doesn't start now.
warriorpluto
267
monroe.LA
Oct 20, 2011
  • Oct 20, 2011
This is all dry test. Poured oil in cylinder one after test to see any difference. Psi went to 76. Not much of difference
warriorpluto
267
monroe.LA
Oct 20, 2011
  • Oct 20, 2011
Ttt
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,081
224
Massachusetts
Oct 21, 2011
  • Oct 21, 2011
What does Cyl 4 do with oil?
Not much change? That entire bank looks off...did you torque the head down properly?
E
ebiggs1
268
Spring Hill, Kansas
Oct 21, 2011
#10
  • Oct 21, 2011
  • #10
It is unlikely a blown head gasket would make all four cylinders down. Are you sure you put the head gasket on at all? Also you shouldn't reuse a head gasket if you pull the head again. Some do but I don't.
warriorpluto
267
monroe.LA
Oct 22, 2011
#11
  • Oct 22, 2011
  • #11
Yes I put it on with the copper spray then torqued them down. Using arp bolts with arp lube
warriorpluto
267
monroe.LA
Oct 22, 2011
#12
  • Oct 22, 2011
  • #12
Managed to get it to run for about twenty seconds and it shut off. RPMs still rose up slowly and went down slowly as a revved up engine. everything on the intake is capped off so should I go on ahead and pull the head? Since its still acting like I have a vacuum leak?
warriorpluto
267
monroe.LA
Oct 23, 2011
#13
  • Oct 23, 2011
  • #13
Took the heads off drivers side cylinders in excellent condition. Passenger side has metal shavings everywhere. Time to sell off my good parts and save for an ls1 swap. I can complete the swap with $2k. Going with a5.3 for now
warriorpluto
267
monroe.LA
Oct 24, 2011
#14
  • Oct 24, 2011
  • #14
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Oct 24, 2011
#15
  • Oct 24, 2011
  • #15
Just out of curiosity, show us some pics of the damage. That sucks, sounds like your motor got too hot.
warriorpluto
267
monroe.LA
Mar 10, 2014
#16
  • Mar 10, 2014
  • #16
Oh just wanted to update it was a bad engine from mps auto salvage. Second one to be exact
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
Engine Cleaning Intake valves with lower intake off
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 11, 2026
limp
Question about my weird timing.
  • 2003 mustang gt modded
  • Apr 22, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 26, 2026
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
