302 still running after turning off ignition
Ive got a 1978 302 in 67 mustang that has been idling high lately (about 1750 rpm) and when I turn off the engine it still fires once or twice before fully stopping. I was trying to adjust the carb to lower the idle today, thinking that this might have something to do with it since both problems started around the same time, but I couldnt seem to get the idle much lower. I went to turn off the engine since i couldnt figure it out, but this time it wouldnt quit running. It was running very rough of course since it had no spark and I unplugged the coil wire to be sure. It was running off of only compression I guess and was able to turn just fast enough to keep the mechanical fuel pump moving to feed itself. It eventually hissed and smoked from the carb and stopped running. I took the air cleaner off and saw some gas on the top of the carb around the air cleaner ring and I heard gas boiling inside. Im not sure if this is a carb issue or something deeper. What should I do here?
