Hey guys, I recently replaced my steering rack with a whole bunch of other suspension mods and had a problem. I fired it up for the first time yesterday and noticed I had no power steering whatsoever. I look underneath the car and I see a noticeable amount of power steering fluid on the floor, next to the driver side rack bolt. I can only assume this leak is coming from one of the two lines on the rack, either the return line or the pressure line. Stupid me didn't do the research prior that mentions a new o-ring should be used so I instead used the same one which might explain the leak.
Now regarding that, here are my questions.
1. Should I put new o-ring's on both lines? I would think so but I read somewhere to only use it on the pressure line so I'm a little confused.
2. Since I have to take the lines off anyway (again...) do you think I should just go ahead and flush the system out? If I want to flush it out, all I would have to do is disconnect the return line and put that in a pan or something right? Also, what's a good fluid to use if choose to flush it? I've heard of people running ATF but what makes that more appealing to use than regular power steering fluid?
3. Lastly, and this may be me, but does anyone have tricks to taking off and re-installing the lines? For some reason it's always been such a bitch job to me, even when I unbolt the rack a bit and slide the shaft off for more clearance. The lines are angled in the gayest way and it's so damn time consuming to line them up in the hole perfectly for the wrench to tighten them down.
Any replies would be great thanks guys!
