  • 1994 - 1995 Specific Tech
Quick TKO question
  • Thread starter Thread starter 1slow95
  • Start date Start date Jan 19, 2006
1slow95
1,797
ohio
Jan 19, 2006
  • Jan 19, 2006
I found a used TKO 600 I'm thinking about buying, but it was used on a 2003 Mustang GT. Will I be able to use it? I'm thinking it'll work, just the bellhousings are different... Anything else I should know before purchasing?
zenboy99
2,212
Madison, WI
Jan 19, 2006
  • Jan 19, 2006
A TKO is a TKO. I went through a week of hell trying to get it to work in my car. Get the driveshaft spacer, and you'll have to add spacers underneath the tranny mount. With my car the tranny was almost hitting the tunnel and actually hit the tunnel going over large bumps. I ditched it and went with the G-Force wich has been perfect so far.
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Jan 19, 2006
  • Jan 19, 2006
To try to "simplify" the installation you can use your stock exhaust hanger mount that is on the crossmember that the stock t-5 bolts onto if you cut part of the tailshaft housing off the tremec. Its useless and only there because the tranny can be used in a million applications. What u cut off will effectively not allow it to be used in the f-body cars im pretty sure. Let me find the corral link where it talks about all this in detail with pictures....
Make sure you index the bell too....
Here is the link.....
http://corral.net/forums/showthread.php?t=732809&page=3&highlight=tremec+vibration
Edit: Looks like they also mod the plate too....i will be doing one of those while the car is in pieces.
WhiteDevil
2,717
San Diego
Jan 19, 2006
  • Jan 19, 2006
My TKO-500 install was straight forward, just as easy as my first T-5 re install. Fit good jsut a little heavier so u might need a helper or a tranny jack. I just got an offset trans mount from www.bieberfever.com and it fit like the stocker.
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Jan 19, 2006
  • Jan 19, 2006
Did you use a spacer or the stock plate thats between the c-member and the tranny?
I think you told me before, but whats that offset trans mount part number? I think you said its off a 96 cobra or something?
Stuck
  • bshipley
  • Aug 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2026
squeak93
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
F
T5 transmission questions
  • Forddestroyer96
  • Aug 27, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 27, 2025
Forddestroyer96
F
I
2023 mustang gt fastback help
  • Izhar8709
  • Mar 22, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 23, 2026
LILCBRA
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
