R&P with Granada disc conversion
  • Thread starter Thread starter 65Rob
  • Start date Start date Feb 10, 2012
65Rob
Victoria, BC, Canada
Feb 10, 2012
  • Feb 10, 2012
I'm planning on switching to a power rack at some point in this build. I did the Granada disc brake change a long while back and seem to recall having to use different length tie rods. Is this something that needs to be taken into consideration with the r&p setup or do they have enough adjustment in them?
Sorry for the all the ignorant questions but it's my specialty
rbohm
6,698
550
204
tucson,az
Feb 10, 2012
  • Feb 10, 2012
it is something you need to consider. try to find a rack that has as close to the same length from tie rod end to tie rod end as your drag link does. that will keep your steering geometry close enough that you can adjust the toe properly. you also want to make sure the steering arms on the rack are about the same length as the ones that connect to the drag link as well. again that will help to keep your steering geometry as close to original as possible. if you dont, you can wind up with a severe case of bump steer.
if you want to swap to rack and pinion steering, go with one of the many kits available that are properly engineered.
65Rob
Feb 10, 2012
  • Feb 10, 2012
I was going to go with the TCP rack or the Randall. I haven't checked into it much, mostly the planning stage. I would like to think they have something for that application, the Grenada swap is pretty common I thought?
rbohm
6,698
550
204
tucson,az
Feb 11, 2012
  • Feb 11, 2012
let them know what spindles you are using, and they can suggest what tie rod ends you need
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Monday at 2:12 PM
mattcrp1
M
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
