Just filling in a few of the holes in the TCP information.
Cost: Manual $1299 (complete), Power $2599 (complete w/pump v-belt or serpentine, billet mounting bracket w/spacers, belt not included) The $2000 is just the rack and installation components. Pump used to be 'optional' but we no longer provide tech support or hose components for OEM pump based systems.
Lock to Lock: 'Quick Ratio' 3 turns, 6-3/8" travel - same for manual or power
Complete Kit: rack, brackets, hardware, steering shaft, shaft bearing w/ retainer, universal joints
Options: aftermarket tilt column w/wiring components, tie-rods with billet sleeves, stainless braided hoses
Bump Steer: corrected
Flex: NONE - wide spread centerlink studs, 4 mounting brackets at frame rails and lower control arm mounts, gusseted brackets at frame rails
Column Change: Stock or aftermarket supported (Flaming River, Ididit) specific u-joints for each column type. Cannot be used with factory non-collapsible tilt or swing-away columns. Recommend later collapsible type or aftermarket.
Other: available for '64-'70 Mustang, '67-'70 Cougar, '60-'65 Falcon/Ranchero/Comet
Other: power system is tunable for road feel, assist, feedback (pump output flow valve, control servo torsion bar. Steering bias also adjustable to perfectly center steering regardless of caster stagger.
Lino Chestang
TCP Product Development
Chris Alston's Chassisworks
