radio
  • Thread starter Thread starter 873Stang
  • Start date Start date Dec 15, 2007
873Stang
221
riverside
Dec 15, 2007
  • Dec 15, 2007
how can i hook it up to where it stays on with out the ign key but when you open the doors it turns off....like the cheveys do
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 15, 2007
  • Dec 15, 2007
Do you want the radio to only turn on when the ignition switch is in the Accessory or Run postion, or anytime the doors are closed?
873Stang
221
riverside
Dec 16, 2007
  • Dec 16, 2007
for when ok you turn the car on right and say you park and turn the car off, you take the key out for the radio to stay on, butwhen you open the doors it turns off, i know the corvettes and some of the higher end chevys do it
bloopbloob
578
Alberta
Dec 16, 2007
  • Dec 16, 2007
my gf's 97 GTP does that.... it's not exactly state of the art or high end anymore...!
V
v8only
2,378
22
49
Dec 16, 2007
  • Dec 16, 2007
you'll need a reverse polarity harmonic rhatostat, and will have to wire it into the green wire of the rhinoculor transplantor
873Stang
221
riverside
Dec 16, 2007
  • Dec 16, 2007
V
v8only
2,378
22
49
Dec 16, 2007
  • Dec 16, 2007
sorry, I was joking
my chevy work truck does this.
to tell you the truth, I don't think its as simple as connecting and splicing wires.
The only thing I can think of is to wire your radio to a constant 12 volt source from the fusebox, so it's always on. You then may be able to wire it into a relay of some sort that's also connected to your door switch, and have the relay turn off when the door is open
HISSIN50
34
129
Dec 16, 2007
  • Dec 16, 2007
GM uses a retained accessory power. The windows and other useful circuit continue to function after the key is turned off.
As Jeremy noted, you can use a latching relay set-up (requires a couple relays). It might be more involved than what you want to do.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 16, 2007
  • Dec 16, 2007
You are looking at maybe $15-$20 worth of parts, all available from Radio Shack. The circuit itself is problably simple with a couple of IC chips. a transistor, a prototype board and a 12 volt relay.
What Rado Shack doesn't have for sale is the skill level needed to read circuit diagrams and do electronic assembly. If you don't have that, then this is a $150 project to get someone to design and build it for you.
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Dec 16, 2007
#10
  • Dec 16, 2007
  • #10
Just turn the key back to ACC
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
O
Resolved 2004 Mustang GT 4.6. No crank, no dash lights, No headlights or dome, No radio, no Hazards.
  • oldtimeracer
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2026
oldtimeracer
O
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
