Ramchargers fan?????
Does anyone have pictures of their ramchargers fan install. I will be installing mine on a 31x19 aluminum radiator and do not want to use the zip tie method. I plan on fabricating some type of bracket out of aluminum and any ideas or pictures of what worked for you guys would be a great help
I have a picture of mine installed, we custom bent little brackets for it, you can see them in the picture.
Thanks for the pic. I got my fan finally. I will have to cut 1 inch off the shroud to get it to fit due to my Griffin radiator has a slanted lower hose connection. Nothing a dremel can't handle. Other than that it works perfect with a 31 inch radiator.
No problem, we did a little cutting on mine as well to make it fit flush against the radiator. This fan cools awesome! (When I remember to turn it on that is :bang: )
