  • SN95 4.6L Mustang Tech
Random hard starting? IAC valve?
  • Thread starter Thread starter 2013 Geee T
  • Start date Start date Apr 26, 2005
2013 Geee T
805
Oak Park, CA
Apr 26, 2005
  • Apr 26, 2005
Every once in awhile when I start my car it will just turn over and over and then finally start. Could that be an IAC valve issue? I only have 30000 miles on the car.
How often should the PCV valve be replaced too?
02gtpony
34
  • Apr 26, 2005
i have an 02 gt with the exact same problem, took it to the dealer and they couldn't figure it out, all they did was reprogram the computer supposedly, and it helped for about a month and now its doing the exact same thing, let me know if you figure it out,
C
Cutler03GT
  • Apr 26, 2005
My 03 did it as well, but hasn't in forever. I have a diablo Predator maybe its programming corrected it unitentionaly? And I'm a former Ford Tech. and have had another 03 Stang come in with the same prob and was unable to diagnose it. So I'm stumped to what causes it. I just no that it doesn't do it anymore and am glad cuz it was rather annoying to have remote start and have it not work because of it.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Apr 26, 2005
  • Apr 26, 2005
Fuel pressure??? Almost sounds like what happens when you run out of gas. It takes a few turns to get the injectors primed again. Wonder if a fuel pump could give you an intermitant problem? Just guessing.
02gtpony
34
  • Apr 26, 2005
i have conciderded the fuel pump, it might be the problem, but it started doing that like 15-20k miles after i got it brand new, i don't think fuel pumps go out that quick, but i still plan on changing it, just finding the time to do it,
Turbo92PGT
746
Auburn Washington
Apr 26, 2005
  • Apr 26, 2005
When mine did that, it was a tube coming from the fuel pump. Had a small hole in it. The new frpp fuel pump I bought came with it, and all has been well ever since. Make sure you put a new gasket around the fuel pump/sending unit, it should come with the fuel pump. Dont learn the hard way and have yours leak gas.
R
rjstaaf
1,310
Somewhere
Apr 26, 2005
  • Apr 26, 2005
How does it run once you get it started? How is the idle? If it were the IAC I would expect idling issues and stalling after it was started.
2013 Geee T
805
Oak Park, CA
Apr 26, 2005
  • Apr 26, 2005
It runs and idles fine. I just remember reading on a post awhile ago that it could be the IAC valve.
Whats involved in doing a fuel pump? Cost?
I hate to replace something thats not the problem and you know the dealer wont do anything unless it does it every time.
2013 Geee T
805
Oak Park, CA
Apr 26, 2005
  • Apr 26, 2005
Wouldnt a bad fuel pump cause problems when the car is running too?
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Apr 26, 2005
#10
  • Apr 26, 2005
  • #10
My problems with the IAC is the car would start but immediatly die. You could hold the gas and keep it running but as soon as you let off it would die again. Once I got rolling I'd keep it revved and the IAC would eventually "kick" in. You could feel it as there would be a slight smoothing of the engine tone.
The fuel pump is not too expensive but you have to drop the gastank to get to it.
That is why I was wondering if it could happen intermitantly. It sounds as though fuel is draining away from the injectors cuasing the hard start. Might have the injectors checked out too...possible have some build up that may be causing problems too.
R
rjstaaf
1,310
Somewhere
Apr 26, 2005
#11
  • Apr 26, 2005
  • #11
I would do the simple things first. Change the fuel filter if you haven't already. Check your air filter, replace it if need be. Replace the PCV valve (stick with Motorcraft replacement). These are all regular maintenance items anyway and if they haven't been replaced in the 30K miles you have then try them first.
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Apr 26, 2005
#12
  • Apr 26, 2005
  • #12
Oh yea...good points. Sometimes the simplist of proceedure takes care of the problem.
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
  • Gulftown980x
  • Jul 29, 2026
squeak93
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
