Random Misfire
stang9150
142
Having an issue with my fox. I have developed a random misfire. If I bring the car up to 1500 to 2000 with no load it misfires like crazy. I have tried two different distributors,cap,rotor,coil,compression test is 150 across the board, I have tried a different set of known good wires.I have unplugged the o2 sensors with no change. The car does have a vortech with a pro M maf.This problem started on a normal drive was fine for 10 miles then started to break up. I have also tried a different ecu even though I could not put my chip in it the misfire was still present. The injectors,maf,fuel pumps all have 1200 miles on them. I have not put a gauge on the fuel rail with the car running yet, but I did hook a screw in gauge to the rail and prime the system and got 30psi at the rail. This pressure will bled off down to 10psi after 10 minutes. I have heard some say this is normal and others say it is not. That possibly the check valve in the pump is bad or the FPR is leaking by, I did not smell ir see any fuel in the FPR vacuum line. I have double and triple checked the timing and been through the valves so mechanically it seems fine. When I go to start the car it will crank tried to hit then die,turn off key add a little throttle and it will fire up. This seems to point to a fuel issue,but a newer pump with that low miles going out I would say is rare. What should the static rail pressure be with just a prime before starting? 17 years of owning this car and it really has me stumped this time. I also need to perform a cylinder balance test later this week,
What size injectors are you runnng.. Is there a tune on the car? Do you know what your AF ratio is? what do your spark plugs look like nand what gap are they set at. What is the FP with the vacuum hose off and plugged- 39-41 is a good starting point, however all of that changes with a blower.
Plugs look normal gap is set to 35,they were replaced yesterday for testing,no change. The injectors are 60lbs with matching maf,vehicle was tuned for this combo on the dyno, the chip is saddled on the factory A9l ecu. Fuel pressure is my next test,I had to get a gauge with a hose to hook to the fuel rail. The inlet elbow for the blower makes it a tight fit. As noted in the topic I tested with a fuel pump prime to 30psi which bled down to 10psi after 10 minutes. The AFR is around 14.6 to 15.0 at idle,sometime it will get a little erratic due to the misfire. Car has been running great till this misfire showed up.
Your AFR at idle is fine- what about under load- that is the key imo. My guess is probably a leaky FPR-- disconnect the vacuum line- does it smell like gas? Do you have a vacuum gauge you can test the FPR with to see if it holds? Even a small piece of hose and suck on it then put your thumb on the hose- you should feel the suction and the pressure should not drop. The gap is a little too big for my preference. I normally set them to .28. I assume you are running A CD ignition box like MSD., Accell, etc?
Hey Mike I checked the fpr and did not smell any gas in the line like if the diaphragm was leaking by. I will give it a check with a hand pump. The car under load seems to reacting normal AFR wise. If I put it in high gear and give it some throttle with a heavy load afr goes rich down into the 11.5 range. I have the blower belt off right now.
Does the problem occur only once the engine has warmed up?
If no, it happens on a cold and warm engine, then have you dumped the codes?
The cylinder balance test below will also dump the codes for you as part of it's process.
Cylinder balance test: use this to find dead or weak cylinders:
Revised 19-Dec-2015 to update RPM ranges and include a more complete description of the engine running tests that are done prior to the cylinder balance test. Added YouTube video to show the process.
The computer has a cylinder balance test that helps locate cylinders with low power output. You’ll need to dump the codes out of the computer and make sure that you have the A/C off, clutch depressed to the floor and the transmission in neutral. Fail to do this and you can’t do the engine running dump codes test that allows you to do the cylinder balance test.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, have the clutch depressed to the floor, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Here's how to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and drivability problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, clutch depressed to the floor and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see www.midwayautosupply.com/Equus-Digital-Ford-Code-Reader/dp/B000EW0KHW Equus - Digital Ford Code Reader (3145It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $22-$36.
If you have idle or IAC/IAB problems and the engine will not idle on its own without mechanically adjusting the base idle speed above 625-750 RPM, this test will fail with random cylinders pointed out every time it runs. The IAC/IAB must be capable of controlling the engine speed to run in the 1300-1500 RPM range. Playing with the base idle speed by adjusting it upwards will not work, the computer has to be able to control the engine speed using the IAC/IAB.
Warm the car's engine up to normal operating temperature. With the test jumper in test position, start the engine and let it stabilize. It should flash a 10 and then a 4 and maybe an 11. If no 11, then there are other codes that will be dumped.
One of the first tests it does is to open the EGR all the way, this will cause the engine to stumble and almost die. If the engine dies here then you have EGR problems.
To start the cylinder balance test, briefly floor the accelerator past 2500 RPM and let off the accelerator. The engine will stabilize at about 1300-1450 RPM and the cut off the fuel injectors one at a time. The engine speed will drop briefly and the computer will turn the fuel injector for the cylinder under test back on. Then it starts the process for the next cylinder. When it has sequenced through all 8 injectors, it will flash 9 for everything OK, or the number of the failing cylinder such as 2 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures.
Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
See
View: https://www.youtube.com/watch?v=HDXrkKS4jTE
for a visual tour through the process. There is no voice narration so you have to listen carefully for the engine sounds.
Do a compression test on all the cylinders.
Take special note of any cylinder that shows up as weak in the cylinder balance test. Low compression on one of these cylinders rules out the injectors as being the most likely cause of the problem. Look at cylinders that fail the cylinder balance test but have good compression. These cylinders either have a bad injector, bad spark plug or spark plug wire. Move the wire and then the spark plug to another cylinder and run the cylinder balance test again. If it follows the moved wire or spark plug, you have found the problem. If the same cylinder fails the test again, the injector is bad. If different cylinders fail the cylinder balance test, you have ignition problems or wiring problems in the 10 pin black & white electrical connectors located by the EGR.
How to do a compression test:
Only use a compression tester with a screw in adapter for the spark plug hole. The other type leaks too much to get an accurate reading. Your local auto parts store may have a compression tester to rent/loan. If you do mechanic work on your own car on a regular basis, it would be a good tool to add to your collection.
With the engine warmed up, remove all spark plugs and prop the throttle wide open with a plastic screwdriver handle between the throttle butterfly and the throttle housing. Crank the engine until it the gage reading stops increasing. On a cold engine, it will be hard to tell what's good & what's not. Some of the recent posts have numbers ranging from 140-170 PSI. If the compression is low, squirt some oil in the cylinder and do it again – if it comes up, the rings are worn. There should be no more than 10% difference between cylinders. Use a blow down leak test (puts compressed air inside cylinders) on cylinders that have more than 10% difference.
I generally use a big screwdriver handle stuck in the TB between the butterfly and the TB to prop the throttle open. The plastic is soft enough that it won't damage anything and won't get sucked down the intake either.
A battery charger (not the trickle type) is a good thing to have if you haven't driven the car lately or if you have any doubts about the battery's health. Connect it up while you are cranking the engine and it will help keep the starter cranking at a consistent speed from the first cylinder tested to the last cylinder.
Happens cold and warm. As noted in the start of this I have performed a compression test and have 150 across all cylinders. I have to perform the balance test later this week. The car took 2 days of troubleshooting had to walk away for a few
