  • SN95 4.6L Mustang Tech
Raptor Shift Light Probs
  • Thread starter Thread starter Cruise157
  • Start date Start date Jan 6, 2008
Cruise157
38
Okinawa, Japan
Jan 6, 2008
  • Jan 6, 2008
I've searched and couldn't find anything. I ops tested the raptor shift light back when they were starting out, and got it working on my 02 GT after months of monkeying around with the PCM. I had the car in storage for about 3 years while I was overseas, and when I came back the shift light wasn't working. I'm trying to troubleshoot, but I can't remember how I got it to work in the first place. Where do you guys have it wired into the PCU? I've tried PIN 26 (green and white) and 104 (pink and white) with no luck. It lights up, there is power going to it, but not lighting up at any RPM. I have it set to 3000 RPM with all setting pins down (off).
Any ideas? Help?
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jan 6, 2008
  • Jan 6, 2008
http://www.raptorperformance.com/Ford/Mustang/mustang_1999to2004.htm
there you go
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jan 6, 2008
  • Jan 6, 2008
all switchs should be off.
sounds like it may have just gone bad
4.6andSlicks
171
Central Connecticut
Jan 6, 2008
  • Jan 6, 2008
Wow, great instructions. Thanks
I plan to install one in the near future.
Cruise157
38
Okinawa, Japan
Jan 6, 2008
  • Jan 6, 2008
Yup... that's how mine is set up. Still doesn't work. *****. I should have bought that 5 year warranty.
R
RAPTOR
17
North Carolina
Jan 8, 2008
  • Jan 8, 2008
Cruise,
If you're using wire taps for the connections, make sure you use the correct size rated for 22 gauge wire (red in color). Some have used the larger ones (blue), and they pierce the wire but don't make good contact with the wire underneath the insulation.
Cruise157
38
Okinawa, Japan
Jan 8, 2008
  • Jan 8, 2008
Everything is soldered directly into the wires. I checked the connections and they're still all good.
R
RAPTOR
17
North Carolina
Jan 8, 2008
  • Jan 8, 2008
Cruise157,
Send it in and we'll check it out.
Put attn: Rick on the package.
Thanks.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
J
Shift light
  • Jfriedrich
  • Jun 22, 2025
SN95 4.6L Mustang Tech Dec 29, 2025
dirk shorter
D
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
  • Gulftown980x
  • Jul 29, 2026
squeak93
