Raspberry pi4 troubles..
Blucifer99
I only understand every 3rd word
Jul 15, 2018
466
31
38
Port Mcnicoll Ontario
I kno its probably a long shot.. but ingot me a raspberry pi4 and a touchscreen dash for my car so I can ditch the laptop and have a digital dash for TS And MLVHD. Now for some reason I cannot get tunerstudio or megalogviewer to load up and install.. I can get it kinda installed but it will not let me extract the files to actually get the pro grams goin... anyone got any insight into this little dilemma. Lmfao.. hit me up if you have had the same trouble and found the solution to this little PIA... Thanks in advance
TunerStudio.com said:
It should be noted, that an Application such as Shadow dash works many aspects of a tablet. It has intense graphics while using Bluetooth, GPS, accelerometers and other sensors. For best results a device with good quality graphics and core processor will provide the best experience.
It is highly recommended that you get a name brand quality device. Many of the very cheap no-brand tablets may be able to run basic apps, but commonly have trouble with buggy drivers that will cause you heart ache. If buying a tablet for this purpose, stick with devices such as Google, Asus, Acer, Samsung, etc.
Android Device:
Android 2.3 or Higher
Bluetooth capability, Host mode USB or WiFi requires 3.0 and higher with a device that
Additional Requirements
Bluetooth to RS232 Adapter (For Wireless bluetooth use)
FTDI Based USB to RS232 Adapter (For USB wired connectivity*)
WiFi to RS232 Adapter for WiFi Operation.
*Your Andoid Device must support USB Host mode or this simply will not work. More and more newer tablets and phones are supporting Host mode, but older devices commonly do not.
Optional feature support:
Accelerometer on Android (most 2.2 or higher Android devices will have this)
GPS sensor
Having the Accelerometer and GPS allows you to capture this additional data.
Raspberry Pi is not one of the SBCs that is known for good Android support.
I'm moving this out of the Digital Tuning forum since it is not that.
