re: cruise control
  • Thread starter Thread starter bigsparky
  • Start date Start date Jun 7, 2004
bigsparky
334
Saskatoon, Saskatchewan
Jun 7, 2004
  • Jun 7, 2004
I bought my car last august and the cruise control has not worked since i've owned it. Today I took some initiative and pulled the inner fender to check for cracks in the vaccuum lines, or disconnected lines. Everything appeared to be good. Next, I pulled the dash pieces off around the steering wheel to check for unhooked wires for the steering wheel controls. Everything looked good. I then took a look at the brake switch (the one that turns the cruise off when you press the brakes). I'm not sure how exactly this thing works, but everything looked connected and operational. There is a vaccuum line hooked up to that switch, when the brake is depressed a little yellow chunk of plastic slides out of the vac. line, i'm assuming this causes a vac. leak which shuts off the cruise???
Anyways, what should i check next???
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jun 7, 2004
  • Jun 7, 2004
fuses?
bigsparky
334
Jun 7, 2004
  • Jun 7, 2004
ECU5.0 said:
fuses?
they're good
any other ideas?
TheBocSez
652
Converse, TX
Jun 7, 2004
  • Jun 7, 2004
Doesnt the VSS control cruise control? Im not sure. Im not even sure if a 5spd has them since I have an AOD, Thought I remembered reading somewhere that it worked with cruise control somehow.
bigsparky
334
Jun 7, 2004
  • Jun 7, 2004
I don't know?? Anyone know?
_jb_
808
Michigan, Berrien County
Jun 7, 2004
  • Jun 7, 2004
Nah, mine has never worked either and I have a T-5. I got the car last September and when I was replacing the heater core I had the dash apart and found no wires cut or anything to disrupt the c/c. I'm blank on this also...
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Jun 7, 2004
  • Jun 7, 2004
mine's always worked... which is surprising... 152,000 and still going strong
Ourobos
260
Jun 7, 2004
  • Jun 7, 2004
Mine has worked 2 times.. the rest of the time it won't turn on..
Bump
Juiced88Coupe
367
Austin, Texas
Jun 7, 2004
  • Jun 7, 2004
sounds like a poll to me.......Mine has always worked in all my stangs (must be lucky)
blk92stangg
583
Hawaii
Jun 7, 2004
#10
  • Jun 7, 2004
  • #10
Mine on my 92 worked find until I did a t5 conversion. I had to drop the steering column and disconnect all the plugs. WHen it came time to button it up, I had one connector that I had no idea where it went, long story short, it was the CC. If anyone knows where it connects to, LET ME KNOW!!!
bigsparky
334
Jun 8, 2004
#11
  • Jun 8, 2004
  • #11
can the servo go bad?
craig gaines
356
DuQuoin, Illinois
Jun 8, 2004
#12
  • Jun 8, 2004
  • #12
well, im not sure how accurate it is but here...
http://auto.howstuffworks.com/frame...m&url=http://dalidesign.com/hbook/ccexpl.html
try this.
Bill Cool
Previously 87MustangGT
1,268
Seymour, CT
Jun 8, 2004
#13
  • Jun 8, 2004
  • #13
Mine's also never worked, and I've checked just about everything...
For Sale 2006 Mustang GT Steering Wheel with Cruise Controls
  • lenko
  • Sep 3, 2026
  • Other Classifieds
Other Classifieds Sep 3, 2026
lenko
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
For Sale 2006 Mustang GT Shaker 500 Head Unit with Bracket
  • lenko
  • Sep 3, 2026
  • Other Classifieds
lenko
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
