so i was told that i have too much oil, its up to the letters full on mine. does it need to be to the crosshatching of full? i know how some of them were mis marked from the factory, how can i tell if mines correct?
TRWXXA
A lot of them were marked wrong. It sounds like your's is one of them (mine goes up to the last L in FULL).so i was told that i have too much oil, its up to the letters full on mine. does it need to be to the crosshatching of full? i know how some of them were mis marked from the factory, how can i tell if mines correct?
The absolute best way to be sure, is to change the oil. Drain all the oil from the front and rear drain plugs and change the filter. Put in 5 quarts of oil, then run the engine for a few seconds. Wait a couple of minutes then check the level. Use a file to mark the dipstick at that level.
If you like, you do those steps with only 4 quarts of oil. That mark will be your "quart low" mark. Then add the last quart and make your "FULL" mark.
cjones
it would be in the crosshatches. the most accurate way is to change the oil and filter, put in 5 qts of oil, start engine, shut off engine and let sit for a couple hours on level ground and check oil level, whereever it shows on the stick is your FULL mark.
normally, up to one quart overfull won't cause any problems.
edit: guess i was a little late
dang then it is on. i was hoping it was too full. then the leaks would stop. i did that i put 5 quarts in and looked and it was at the F in full.
DigitalGhost
Mine is goofy too. Ive changed my own oil and been confused. I took it to a shop out here, they changed the oil, and still got the same results.
Next time I gotta have the dipstick notched I guess.
