Sorry to start new thread, but new problem, plus there was some confusion in last thread. I had just got finished with a 4cyl to v8 swap. 88 coupe with 90 motor, aod, and wiring harness with maf. Battary relocated to trunk. Everything worked fine before pulling everything. Ok, now thats out the way, at first when i first went to start, turn the key, all dash lights and dinging came on, turn the key one more to bump starter and nothing, didnt try to even crank, not even a small sound of anything doing anything. Like i didnt even turn the key over. I tried the one new battary and anther charged battary. Then hooked charger to battary and still same thing. I do NOT have the 4 prong neutral saftey switch hooked up, dont now if that is it. I have checked the starter relay/noid and it is wired right. All grounds is hooked up, from block to frame, and the one behind the back of the motor. I was told to take a screw driver from one post to the other on the relay. I did and sparks (as planned) and nothing. I tried again and no sparks and now when i turn key to anything no lights, no dingingg, no nothing. Checked all fuses under dash and none blown. Pulled computer for some fuse that isent there or i cant find, to see if its blown, cant find it. So now what??????? im lost and dont know what to do next. I need help VERFY badly, please help, with either problem, and yes the little wire on the relay is plugged up, and tried two different relays, sorry for being so long, but iwantted to give as much info, plz i really need help.
